EDUP amp power output
Does anyone have a graph/table/function relating current drain through an EDUP amp to RF power out for a given supply voltage, say 12V?
Re: EDUP amp power output
Try George M1GEO's website? There's a bit about these there IIRC.
I can give you a datasheet for the devices and the switch.
There are two in parallel.
So don't expect more than 5W.
It takes about 0.3A quiescent (Tx mode).
And about 1A-1.5A maximum.
There is an internal 6v SM PSU so it really runs at 6V.
Does this help any?
Does this help any?
200186C.pdf- RF switch
- (245.75 KiB) Downloaded 270 times
innotionyp242034datasheet.pdf- 2.4 GHz WiFi PA
- (568.48 KiB) Downloaded 298 times
Thanks for our advice M0YDH.
Thanks G0LJF for the datasheet. It has a nice Icc vs Output Power graph in it.
73 Graham
73 Graham
