EDUP amp power output
g3yjr
Post by g3yjr » Tue Aug 11, 2020 10:35 am
Does anyone have a graph/table/function relating current drain through an EDUP amp to RF power out for a given supply voltage, say 12V?
M0YDH
Re: EDUP amp power output
Post by M0YDH » Tue Aug 11, 2020 5:11 pm
Try George M1GEO's website? There's a bit about these there IIRC.
G0LJF
Post by G0LJF » Thu Aug 13, 2020 8:50 am
I can give you a datasheet for the devices and the switch.
There are two in parallel.
So don't expect more than 5W.
It takes about 0.3A quiescent (Tx mode).
And about 1A-1.5A maximum.
There is an internal 6v SM PSU so it really runs at 6V.
Does this help any?
200186C.pdf
RF switch
(245.75 KiB) Downloaded 264 times
innotionyp242034datasheet.pdf
2.4 GHz WiFi PA
(568.48 KiB) Downloaded 290 times
g3yjr
Post by g3yjr » Wed Aug 19, 2020 4:41 pm
Thanks for our advice M0YDH.
Thanks G0LJF for the datasheet. It has a nice Icc vs Output Power graph in it.
73 Graham
