Now my MiniTiouner works well with MiniTioune (=Tutioune for this specific Home brewed tuner).
- Minitioune V0.1c_beta SR250.jpg (379.22 KiB) Viewed 13836 times
I have tested SR125 up to SR5000.
latency is very very short for low SR as I am using a very little buffer.
- vLC receiving TS from Minitioune1.jpg (328.87 KiB) Viewed 13836 times
I use VLC for decoding video and audio. Latter it will be done by MiniTioune.
Finally I used very few components:
- FT2232H minimodule
- Samsung DNBU10711IST NIMtuner
- 74HC10 (DIP14)
- montage avec NIM samsung_.jpg (128.99 KiB) Viewed 13836 times
about power supply, we need 5v, 3.3v and 1v.
I use an external 5V power supply(but we can add a 5V regulator if we want to use 11v to 14v for mobile...)
I have added a 3.3 TO220 regulator and a LP3879 with only 3 capacitors for 1V.
I will add a LNBP21 to produce 13v, 14, 18v or 19v for LNB or LNA power supply and it gives also 22kHz signal.
I have tested also SHARP BS2F7HZ0169 that is OK for low SR;
Next week I will test the EARDATEK EDS-4B47FF1B+ that we can find inside TBS5980 ot Prof7500 USB tuner.
List of NIM that would be good:
Samsung
- DNBU10512IST ( utilisé aussi par ModuleNIM de l'AP-IPbox 9000HD) 3 unités en test à la maison
- DNBU10711IST ( 1 acheté sur Ebay utilisé sur proto MiniTioune, 10 autres arrivent dans 1 ou 2 jours)
- DNBU24513IST ( utilisé aussi par ModuleNIM de l'AZbox Premium HD+)
- DNBU10512ISA (?)
EARDATEK
- EDS-4B47FF1B+ ( 2 bought on AliExpress, will be tested next week)
(1000 available on ali express)
http://fr.aliexpress.com/item/EDS-4-b47 ... dVersion=1
SHARP
- BS2F7HZ1167 ( horizontal)
- BS2F7VZ1167 (vertical)
- BS2F7HZ1169
- BS2F7VZ1169
- BS2F7HZ0167
- BS2F7VZ0167
- BS2F7HZ1069 (1000 available on ali express)
- BS2F7VZ1069 ( 3 bought onr Ebay and already tested using MiniTioune )
http://fr.aliexpress.com/item/BS2F7HZ01 ... dVersion=1
SERIT
- SP710Vb half nim tuner
- SP4760Vb Dual Half Nim Tuner avec 2 STV6110
- SP760Vb half nim tuner with STV6110
- SP7760V Half Nim Tuner with STB6111
- SP1061V Half Nim Tuner with STB6111
- SP2336 Nim Tuner
- SP3206 Nim tuner avec STV0903 et STV6130 250 MHz ! Fantastic! we can go down to 250 MHz!!
- SP460V Half Nim Tuner with STV6120 250 MHz
- SP2246 nim tuner STV0913 STV6111
LG
- TDQX-S001F (LG) (chips STV0903B & STV6110A) ( used in SetTopBox Digiline 7000HD)
... and surely many others...
Beta version of MiniTioune is available for betaTester.
I have began to get my notes for creating the schematic.
We have to decide definitively which option we put. I suggest to put both connectors that fits for SHARP/EARDATEK or Samsung NIM.
We can add easily some led to know that TS is present, or a PIC to switch something when TS is present or for counting packets ...???
Who want to create some proto pcb for that?
Shematics are on vivadatv forum.
Jean Pierre F6DZP
