Portsdown 4 & Picotuner
Good afternoon. I have 3 Portsdown 4's and my Picotuner works fine on one of them. It also works on Opentuner, however it is not recognised by my other 2 Portsdowns. Any ideas, the PD4's work normally in all other aspects.
Kind regards
Graham M1ASR
Kind regards
Graham M1ASR
Re: Portsdown 4 & Picotuner
Update!
Problem cured by plugging another dongle (Audio) into PD4. Works fine now, no idea why, something going on in USB Bus I guess.
I have to leave the Audio Dongle plugged into the RPi, for the Picotuner to be recognised on boot up. Work around for now, but wonder what's going on?
Perhaps you have the dongle selected for audio out ?
I've tried with rpi and HDMI selected with the same result. I'm assuming it needs some device connected, or it won't be recognised. I wanted just monitor video, it appears to be an issue. As soon as I plug the audio dongle in, the PIcotuner is immediately recognised.
I don't have the same issue. so it is something different. Did you try setting no audio?
Yes tried no audio, seems an issue on all 3 PD4's - Picotuner only works with usb audio dongle. wonder if I need to update firmware?
