Portsdown 4 & Picotuner
M1ASR
Post by M1ASR » Mon Jan 12, 2026 2:25 pm
Good afternoon. I have 3 Portsdown 4's and my Picotuner works fine on one of them. It also works on Opentuner, however it is not recognised by my other 2 Portsdowns. Any ideas, the PD4's work normally in all other aspects.
Kind regards
Graham M1ASR
M1ASR
Re: Portsdown 4 & Picotuner
Post by M1ASR » Mon Jan 12, 2026 2:40 pm
Update!
Problem cured by plugging another dongle (Audio) into PD4. Works fine now, no idea why, something going on in USB Bus I guess.
M1ASR
Post by M1ASR » Mon Jan 12, 2026 3:00 pm
I have to leave the Audio Dongle plugged into the RPi, for the Picotuner to be recognised on boot up. Work around for now, but wonder what's going on?
Post by g0mjw » Mon Jan 12, 2026 3:15 pm
Perhaps you have the dongle selected for audio out ?
M1ASR
Post by M1ASR » Mon Jan 12, 2026 5:41 pm
I've tried with rpi and HDMI selected with the same result. I'm assuming it needs some device connected, or it won't be recognised. I wanted just monitor video, it appears to be an issue. As soon as I plug the audio dongle in, the PIcotuner is immediately recognised.
Post by g0mjw » Mon Jan 12, 2026 6:07 pm
I don't have the same issue. so it is something different. Did you try setting no audio?
M1ASR
Post by M1ASR » Mon Jan 12, 2026 6:18 pm
Yes tried no audio, seems an issue on all 3 PD4's - Picotuner only works with usb audio dongle. wonder if I need to update firmware?
M1ASR
Post by M1ASR » Tue Jan 20, 2026 6:02 pm
Update: Purchased a "White Dongle" to no avail.
PD receives and streams sound, but freezes after about 15 secs. The original white dongle isn't available it seems, as I notice that there is a red flashing light in the dongle case when streaming. Picotuner works fine on Laptop/PC and the sound is fine. I've also swapped the usb lead.
kf5dey
Post by kf5dey » Fri Feb 27, 2026 5:54 am
For Dave G8GKQ
The Portsdown is just a fantastic piece of kit!
We use it to test transmission and resception of the ISS HamTV downlink with our system...via PicoTuner on the receive end.
We want to make the ISS HamTV RX Merger be a power on auto start. We have figured out the comand to do it, the scripting is stumping us right now.
So Merger has to autostart as well as RX.
Any advice?
Thanks,
KF5DEY
Cowtown Amateur Radio Club
Ft Worth TX
https://www.cowtownarc.org/radio-operat ... ellite-ops
