Analog TV with Pluto SDR
2e0yml
Post by 2e0yml » Tue May 16, 2023 9:03 am
I'm new to ATV and recently started down the QO-100 rabbit hole for which I've picked up a Pluto SDR. My QTH also happens to be close to GB3TV which is a 23cm analog TV repeater. Is there any way to generate analog TV signals with the Pluto or do I need to use a separate modulator?
There are some gnuradio flowgraphs for generating TV signals but nothing as polished as Portsdown etc which might be more suited to a newbie.
Thanks,
Matt
M0SKM
Re: Analog TV with Pluto SDR
Post by M0SKM » Tue May 16, 2023 9:50 am
GB3TV has had some changes including a DATV input/output. Ask Phil G8XTW for details.
http://www.dunstabledownsradioclub.org/
See the contact page.
Steve
2e0yml
Post by 2e0yml » Tue May 16, 2023 12:00 pm
Hi Steve,
Thanks Steve. Nice to see you here - I think this is the second time we have crossed paths online, but not on air yet! (Although I do hear you regularly with Arthur...) Will ask Phil about DATV on GB3TV next time we speak.
I'm still interested in whether I can generate analog TV signals with the pluto - even as just a purely academic exercise.
Post by G8GKQ » Tue May 16, 2023 12:11 pm
Hi Matt
The simple answer is no (to generating FM ATV from a Pluto).
It could probably be done if you wrote some custom firmware, but I doubt that anyone would see it is a good return on their time.
Far better to get going with digital ATV using the Portsdown or DATV Easy.
Perhaps something to discuss with those manning the BATC stand/shop at Dunstable this Sunday!
M0SKM
Post by M0SKM » Tue May 16, 2023 12:47 pm
Matt I will be at the rally on Sunday, hope to see you there.
Steve
Post by G8GKQ » Tue May 16, 2023 1:10 pm
Hi Steve
Noel will be manning the stand and shop with help from Justin G8YTZ. I have a family wedding in Shropshire this weekend.
2e0yml
Post by 2e0yml » Tue May 16, 2023 4:55 pm
Thanks Dave.
It turns out that sdrangel has an ATV modulator, although it only sends luminance data but I was able to get a B&W picture across my desk.
I will be at the rally albeit directing traffic. If anyone reading sees a ginger beard in a hi-vis jacket, come and talk to me about ATV :)
G8KOE
Post by G8KOE » Tue May 16, 2023 5:22 pm
Hi Matt,
I have a Solent/Worthing 23cms TX KIT.
Also the PLL KIT and XTALS
https://wiki.batc.org.uk/images/f/f1/Solent_Tx.pdf
The link above will give you some information.
If intrested contact me.
73's
Martin
G8KOE
DL5BCA
Post by DL5BCA » Wed May 17, 2023 9:49 am
if someone is looking for something well-functioning analogue, they will also find it here:
https://pe1acb.nl/
very good and cheap.
Crafted by an OM at home.
Return to “Getting Started?”
