Analog TV with Pluto SDR
2e0yml
Post by 2e0yml » Tue May 16, 2023 9:03 am
I'm new to ATV and recently started down the QO-100 rabbit hole for which I've picked up a Pluto SDR. My QTH also happens to be close to GB3TV which is a 23cm analog TV repeater. Is there any way to generate analog TV signals with the Pluto or do I need to use a separate modulator?
There are some gnuradio flowgraphs for generating TV signals but nothing as polished as Portsdown etc which might be more suited to a newbie.
Thanks,
Matt
M0SKM
Re: Analog TV with Pluto SDR
Post by M0SKM » Tue May 16, 2023 9:50 am
GB3TV has had some changes including a DATV input/output. Ask Phil G8XTW for details.
http://www.dunstabledownsradioclub.org/
See the contact page.
Steve
2e0yml
Post by 2e0yml » Tue May 16, 2023 12:00 pm
Hi Steve,
Thanks Steve. Nice to see you here - I think this is the second time we have crossed paths online, but not on air yet! (Although I do hear you regularly with Arthur...) Will ask Phil about DATV on GB3TV next time we speak.
I'm still interested in whether I can generate analog TV signals with the pluto - even as just a purely academic exercise.
Post by G8GKQ » Tue May 16, 2023 12:11 pm
Hi Matt
The simple answer is no (to generating FM ATV from a Pluto).
It could probably be done if you wrote some custom firmware, but I doubt that anyone would see it is a good return on their time.
Far better to get going with digital ATV using the Portsdown or DATV Easy.
Perhaps something to discuss with those manning the BATC stand/shop at Dunstable this Sunday!
M0SKM
Post by M0SKM » Tue May 16, 2023 12:47 pm
Matt I will be at the rally on Sunday, hope to see you there.
Steve
Post by G8GKQ » Tue May 16, 2023 1:10 pm
Hi Steve
Noel will be manning the stand and shop with help from Justin G8YTZ. I have a family wedding in Shropshire this weekend.
2e0yml
Post by 2e0yml » Tue May 16, 2023 4:55 pm
Thanks Dave.
It turns out that sdrangel has an ATV modulator, although it only sends luminance data but I was able to get a B&W picture across my desk.
I will be at the rally albeit directing traffic. If anyone reading sees a ginger beard in a hi-vis jacket, come and talk to me about ATV :)
G8KOE
Post by G8KOE » Tue May 16, 2023 5:22 pm
Hi Matt,
I have a Solent/Worthing 23cms TX KIT.
Also the PLL KIT and XTALS
https://wiki.batc.org.uk/images/f/f1/Solent_Tx.pdf
The link above will give you some information.
If intrested contact me.
73's
Martin
G8KOE
DL5BCA
Post by DL5BCA » Wed May 17, 2023 9:49 am
if someone is looking for something well-functioning analogue, they will also find it here:
https://pe1acb.nl/
very good and cheap.
Crafted by an OM at home.
I always have crazy ideas.
Please don't be surprised.
Peterarnld
Post by Peterarnld » Mon Mar 24, 2025 5:38 pm
Thanks,
Matt
Hi Matt,
I'm also interested in ATV and exploring the capabilities of the Pluto SDR. Have you made any progress in generating analog TV signals with it? Did you end up using a separate modulator, or were you able to achieve good results with GNU Radio?
Also, do you think this plutsdr https://www.sdrstore.eu/software-define ... hz-6ghz-en/ would be a good choice for experimenting with ATV transmission?
Looking forward to your thoughts!
Return to “Getting Started?”
