Longmynd/Winterhill Client - Feature Requests/Bug Reports
zr6tg
Post by zr6tg » Mon Oct 31, 2022 8:28 am
Hi All,
I'm doing some work on the Longmynd and Winterhill Clients in the coming two weeks. While I'm at it I can sort out any feature requests still outstanding. Please post your features requests/bugs in this thread:
Longmynd Client: https://www.zr6tg.co.za/longmynd-client/
Winterhill Client: https://www.zr6tg.co.za/winterhill-datv ... er-client/
Thanks for everyone who has given feedback!
- Tom - ZR6TG
G8KOE
Re: Longmynd/Winterhill Client - Feature Requests/Bug Reports
Post by G8KOE » Mon Oct 31, 2022 8:48 am
Hi Tom,
I am using the Longmynd Client what an excellent program.
Would it be possible to have an audio meter to setup levels and help to confirm that you are transmitting audio without the volume turned up.
Hope to have Winterhill Client installed this week.
73's
Martin
G8KOE
zr6tg
Post by zr6tg » Mon Oct 31, 2022 2:26 pm
Hi Tom,
73's
Martin
G8KOE
Hi Martin,
That is a great idea. I'll add it to the list and look into it :)
T
G8KOE
Post by G8KOE » Mon Oct 31, 2022 3:10 pm
Hi Tom,
Another request for a Raspberry Pi shutdown button.
73's
Martin
G8KOE
PE5PVB
Post by PE5PVB » Mon Oct 31, 2022 4:03 pm
I would like to have a quicktune option in LongMynd. For example a popup where you can:
- Select antenna input
- Set frequency
- Set LO offset
- Set Symbolrate
Is it possible to make it compatible for the Knucker too?
zr6tg
Post by zr6tg » Mon Oct 31, 2022 4:42 pm
- Set frequency
- Set LO offset
- Set Symbolrate
Can you elaborate on this please, you can already set all these settings in the longmynd client ?
It looks like it should be possible. I don't have any knucker hardware yet, but I'll see if I can order some. Going onto the list :)
zr6tg
Post by zr6tg » Mon Oct 31, 2022 4:43 pm
Hi Tom,
73's
Martin
G8KOE
Going onto the list, should be easy to add.
PE5PVB
Post by PE5PVB » Tue Nov 01, 2022 1:17 pm
How? I use this especially for normal reception on 2m and 70cm.
zr6tg
Post by zr6tg » Tue Nov 01, 2022 1:42 pm
Ah, I understand, You can change the frequency and sr quickly in the manual control group, but the offset is being seen as fixed which obviously becomes a problem on 2m/70cm. I'll add something in for that. Sorry, I need to remember its not just QO-100 :p we don't have 70cm/2m transmissions here in South Africa (yet, I need to do something about that)
Going on the list :)
G8KOE
Post by G8KOE » Fri Dec 02, 2022 11:10 am
Hi Tom,
I am having a problem with the Longmynd Client locking up if I try to adjust the audio level with the slider.
My PC is running Win 11 i7.
I have to use Task Manager to end the process and the restart the program.
73's
Martin
G8KOE
