MiniTiouner Pro
g6hfs
MiniTiouner Pro
Post by g6hfs » Fri Jun 10, 2022 6:08 pm
Is there a link to the MiniTiouner Pro software as I am unable to find
Brian (G6HFS)
M5TXJ
Re: MiniTiouner Pro
Post by M5TXJ » Fri Jun 10, 2022 7:49 pm
Hi Brian,
Not sure which software you're looking for. The Minitiouner Pro works perfectly with Minitioune software or under the control of a Ryde as is mine.
73 Dave
Re: MiniTiouner Pro
Post by g0mjw » Fri Jun 10, 2022 8:09 pm
I suspect Windows software. It is all in the Wiki but...
For the F6DZP Windows software http://www.vivadatv.org/viewforum.php?f=86 - you need to be registered on the fourn to download from http://www.vivadatv.org/viewforum.php?f=60
There is always Ryde or Portsdown4 as an alternative, running on a PI.
g6hfs
Re: MiniTiouner Pro
Post by g6hfs » Fri Jun 10, 2022 8:59 pm
Thanks for replys I just thought the software was called dualtioune.
M5TXJ
Re: MiniTiouner Pro
Post by M5TXJ » Mon Jun 13, 2022 1:45 pm
Brian,
Dualtioune has never been released. Just have to use Minitioune, a Portsdown or a Ryde on the master USB.
73 Dave.
Re: MiniTiouner Pro
Post by g0mjw » Mon Jun 13, 2022 3:01 pm
Although DualTioune was never released, there is a scan and Tioune application that does make use of the second tuner so display a spectrum. It doesn't need a 2nd USB port to do this. See the VivaDATV webforum for more information.
g6hfs
Re: MiniTiouner Pro
Post by g6hfs » Mon Jun 13, 2022 3:37 pm
Thanks for the replies, can you plug both usb leads in and run two instances of MiniTiouner, or two pc,s with one usb port pluggered in on each seperate pc?
Brian (G6HFS)
Re: MiniTiouner Pro
Post by g0mjw » Mon Jun 13, 2022 4:28 pm
No
g6hfs
Re: MiniTiouner Pro
Post by g6hfs » Wed Jun 15, 2022 8:18 pm
Any one else used a MiniTiouner and MiniTiouner Pro on one PC, as it seems to work ok but now need dual screen or higher res to fit both windows on screen.
Brian (G6HFS)
M0SKM
Re: MiniTiouner Pro
Post by M0SKM » Wed Jun 15, 2022 9:12 pm
Hi Brian,
Yes two Minitiouners work fine but I don't use the Pro. There is a conflict If I try to start two instances of Minitioune simultaneously.
Steve
