MiniTiouner Pro
MiniTiouner Pro
Is there a link to the MiniTiouner Pro software as I am unable to find
Brian (G6HFS)
Brian (G6HFS)
Re: MiniTiouner Pro
Hi Brian,
Not sure which software you're looking for. The Minitiouner Pro works perfectly with Minitioune software or under the control of a Ryde as is mine.
73 Dave
73 Dave
Re: MiniTiouner Pro
I suspect Windows software. It is all in the Wiki but...
For the F6DZP Windows software http://www.vivadatv.org/viewforum.php?f=86 - you need to be registered on the fourn to download from http://www.vivadatv.org/viewforum.php?f=60
There is always Ryde or Portsdown4 as an alternative, running on a PI.
Re: MiniTiouner Pro
Thanks for replys I just thought the software was called dualtioune.
Re: MiniTiouner Pro
Brian,
Dualtioune has never been released. Just have to use Minitioune, a Portsdown or a Ryde on the master USB.
73 Dave.
73 Dave.
Re: MiniTiouner Pro
Although DualTioune was never released, there is a scan and Tioune application that does make use of the second tuner so display a spectrum. It doesn't need a 2nd USB port to do this. See the VivaDATV webforum for more information.
Re: MiniTiouner Pro
Thanks for the replies, can you plug both usb leads in and run two instances of MiniTiouner, or two pc,s with one usb port pluggered in on each seperate pc?
Brian (G6HFS)
Brian (G6HFS)
Re: MiniTiouner Pro
Any one else used a MiniTiouner and MiniTiouner Pro on one PC, as it seems to work ok but now need dual screen or higher res to fit both windows on screen.
Brian (G6HFS)
Brian (G6HFS)
- 447EA237-5C4A-40DA-A0FC-1FDEA569B2BC.jpeg (919.47 KiB) Viewed 8273 times
- A8430278-C04B-4ED0-90E5-0C85E3C672FA.jpeg (784.32 KiB) Viewed 8273 times
- E6BA9BAD-98B0-4419-90B7-1D99B8D07DCE.jpeg (1.05 MiB) Viewed 8273 times
- 3B940637-6E13-4BFA-BFAF-F0359E6D4EE1.jpeg (660.86 KiB) Viewed 8273 times
Re: MiniTiouner Pro
Hi Brian,
Yes two Minitiouners work fine but I don't use the Pro. There is a conflict If I try to start two instances of Minitioune simultaneously.
Steve
Steve
