Portsdown Help
gu6efb
Portsdown Help
Post by gu6efb » Mon Oct 21, 2019 10:33 am
Just getting going on DATV and have the Minitiouner receiver all setup and working.
for TX now have RPI with Portsdown latest version 201910103 installed setup and running.
I have now connected my Lime mini and have TX images across the shack
from the Portsdown I have now connected the Minitiouner connected to the RPI and can UPD received video to VLC
Reading on the forum I saw this from Noel
"A slight confusion now is that you can plug the MiniTiouner USB tuner hardware in to the Portsdown system and it will display the pictures, thereby becoming a full DATV transceiver and replacing the need for a PC."
What do I need to install/setup to be able to achieve this?
I am slowly making progress hopefully transmitting shortly.
73 Keith GU6EFB
G8PEF
Re: Portsdown Help
Post by G8PEF » Mon Oct 21, 2019 10:44 am
Hi, Keith
I'm about to try this out (next weekend) so I'll report on how it went in due course...
However, it's my understanding that as long as your Portsdown has the latest software update (with LongMynd receiver capability) then simply plugging the Minitiouner into a USB port on the Pi is all that's required... Selecting RX from the Portsdown Menu should then allow you to view the output of Minitioner, with appropriate button presses :)
John
G8PEF
gu6efb
Re: Portsdown Help
Post by gu6efb » Mon Oct 21, 2019 11:04 am
Hi John
I have just figured this out You need to select the OMS player
Why this did not work before I don't know but its working now.
Good luck with your project this weekend
73 Keith GU6EFB
Re: Portsdown Help
Post by G8GKQ » Mon Oct 21, 2019 11:12 am
Keith
The capability is fully described in CQ-TV 265
gu6efb
Re: Portsdown Help
Post by gu6efb » Mon Oct 21, 2019 11:19 am
Hi Dave
As normal for me trying to run before I can walk, I will re-read CQ-TV 265 again
73 Keith
G8PEF
Re: Portsdown Help
Post by G8PEF » Mon Oct 21, 2019 4:59 pm
Oops! Me too....
John
