Picotuner v3 panel 3d model
ct7afy
Post by ct7afy » Sun Jan 05, 2025 7:25 pm
Does somebody know where can I find a Picotuner V3 panel 3d model (stl file) ?
Re: Picotuner v3 panel 3d model
Post by g0mjw » Mon Jan 06, 2025 3:57 pm
ct7afy
Post by ct7afy » Sat Jan 11, 2025 7:19 pm
I believe that file is not for the latest version of PicoTuner. The Power and USB ports are not aligned with the panel.
Post by g0mjw » Sat Jan 11, 2025 7:34 pm
Could be the older version. I will have a look.
Post by g0mjw » Sat Jan 11, 2025 7:38 pm
Is this the right size?
Test.pdf
(209.71 KiB) Downloaded 298 times
Post by g0mjw » Sat Jan 11, 2025 7:46 pm
OK - So the one on the Wiki is the correct one. I thought it had to be. What you have done is print the version 1 panel and not the version 3 panel. Scroll down.
https://wiki.batc.org.uk/File:PicoBackPanelSTL.zip
ct7afy
Post by ct7afy » Sat Jan 11, 2025 9:42 pm
Many thanks Mike. It looks ok now.
ct7afy
Post by ct7afy » Fri Jan 17, 2025 11:18 pm
Hi Mike, is there a model for the front panel ?
Post by g0mjw » Fri Jan 17, 2025 11:28 pm
No - I figured people can drill 4 holes by themselves.
