Picotuner v3 panel 3d model
Does somebody know where can I find a Picotuner V3 panel 3d model (stl file) ?
Re: Picotuner v3 panel 3d model
I believe that file is not for the latest version of PicoTuner. The Power and USB ports are not aligned with the panel.
- IMG_8857.jpeg (1.89 MiB) Viewed 6535 times
Could be the older version. I will have a look.
Is this the right size?
OK - So the one on the Wiki is the correct one. I thought it had to be. What you have done is print the version 1 panel and not the version 3 panel. Scroll down.
https://wiki.batc.org.uk/File:PicoBackPanelSTL.zip
Many thanks Mike. It looks ok now.
Hi Mike, is there a model for the front panel ?
No - I figured people can drill 4 holes by themselves.
