Portsdown 4 Icom 905
VK3BKQ
Post by VK3BKQ » Sat Nov 09, 2024 11:08 am
Is it possible to output from Portsdown to composite input on Icom 905 ?
g6hfs
Re: Portsdown 4 Icom 905
Post by g6hfs » Sat Nov 09, 2024 9:41 pm
Yes, you need this, perhaps you can buy from supplier there.
You need to set video out on pi, also disconnect lcd screen.
https://thepihut.com/products/a-v-and-r ... v1qTMrud3A
VK3BKQ
Post by VK3BKQ » Sun Nov 10, 2024 11:35 am
Thanks Brian, I was hoping I could leave touch screen
connected.
g6hfs
Post by g6hfs » Sun Nov 10, 2024 11:43 am
I think portsdown 5 (the next gen) you will be able to, for time being you will have to use k/brd and mouse.
Post by radiogareth » Sun Nov 10, 2024 1:49 pm
This gives you a variety of options (test cards, pictures, PiCamera...)
https://wiki.batc.org.uk/BATC_Video_Source
Cheap to build.....
Post by G8GKQ » Mon Nov 11, 2024 10:40 am
Let's clear up any confusion in the answer to this question.
  • The Portsdown 4 does not support composite video output (as needed to input to an IC-905). It may be possible to make it do it, but I reserve the right to inadvertently (not intentionally) disable any work-arounds during future updates. It is just not something that I test.
  • The Portsdown 2020 does support composite video output and will continue to do so.
  • The best solution (as Gareth says) is to use the BATC Video Source https://wiki.batc.org.uk/BATC_Video_Source which is designed for the job and uses a Raspberry Pi Zero.
  • The Portsdown 5 will be not support composite video output. It will support HDMI video output.
I used a BATC Video source for the review tests of the IC-905 with good results. Note that there is also a BATC HDMI source with similar capabilities, but for HDMI https://wiki.batc.org.uk/BATC_HDMI_Source
Future projects will all use digital video in some form (HDMI, SRT, SDI etc). The IC-905 is using modes that were more appropriate 20 years ago.
g6hfs
Post by g6hfs » Mon Nov 11, 2024 12:09 pm
Apologies for my misunderstanding
VK3IE
Post by VK3IE » Mon Nov 11, 2024 7:47 pm
Highs recommend the https://wiki.batc.org.uk/BATC_Video_Source
Easy Compact and a built in Camera and test cards easy.
Cheers
Vk3IE
