Portsdown 4 Icom 905
Is it possible to output from Portsdown to composite input on Icom 905 ?
Re: Portsdown 4 Icom 905
Yes, you need this, perhaps you can buy from supplier there.
You need to set video out on pi, also disconnect lcd screen.
https://thepihut.com/products/a-v-and-r ... v1qTMrud3A
Thanks Brian, I was hoping I could leave touch screen
connected.
connected.
I think portsdown 5 (the next gen) you will be able to, for time being you will have to use k/brd and mouse.
This gives you a variety of options (test cards, pictures, PiCamera...)
https://wiki.batc.org.uk/BATC_Video_Source
Cheap to build.....
Cheap to build.....
Let's clear up any confusion in the answer to this question.
Future projects will all use digital video in some form (HDMI, SRT, SDI etc). The IC-905 is using modes that were more appropriate 20 years ago.
- The Portsdown 4 does not support composite video output (as needed to input to an IC-905). It may be possible to make it do it, but I reserve the right to inadvertently (not intentionally) disable any work-arounds during future updates. It is just not something that I test.
- The Portsdown 2020 does support composite video output and will continue to do so.
- The best solution (as Gareth says) is to use the BATC Video Source https://wiki.batc.org.uk/BATC_Video_Source which is designed for the job and uses a Raspberry Pi Zero.
- The Portsdown 5 will be not support composite video output. It will support HDMI video output.
Apologies for my misunderstanding
Highs recommend the https://wiki.batc.org.uk/BATC_Video_Source
Easy Compact and a built in Camera and test cards easy.
Cheers
Vk3IE
Cheers
Vk3IE
