Portsdown 4 - Flickering 5 inch Display?
Post by G8GKQ » Thu Sep 15, 2022 9:48 am
Hi All
I'm doing some off-topic software development work and using my Portsdown 4 with the 5 inch display. Every minute or so it flickers to black and then comes back on again. I'm pretty sure that it is not a software issue.
Has anyone else observed this, and if so do they know a cure? I'm wondering if turning the brightnesss down might help, but I can't easily access the control at the moment.
M0SKM
Re: Portsdown 4 - Flickering 5 inch Display?
Post by M0SKM » Thu Sep 15, 2022 10:31 am
I posted this in January and hoped you might have an answer.
viewtopic.php?f=129&t=7591&p=29676#p29676
Situation is the same; I'm just living with it. Bought a second screen and it's the same.
Steve
Post by G8GKQ » Thu Sep 15, 2022 10:43 am
Hi Steve
Sorry - I missed the flickering part of that post. Hopefully the touch improved with the software changes that I made in March (update 202203071 changed the way that touch was handled to make the 5 inch screen more responsive).
The next step is probably to work out if it is the backlight or the LCD causing the flicker.
I take it that adding "lcd_framerate=53" to config.txt is not a reliable fix?
M0SKM
Post by M0SKM » Thu Sep 15, 2022 11:44 am
Touch screen sensitivity is fine now, wifi still doesn't work and the screen still flickers to black occasionally. I think the framrate tweak made an improvement; not a cure.
Steve
Post by g0mjw » Thu Sep 15, 2022 12:08 pm
I wonder about the flickering. The screen has a pot that sets the brightness, but that is probably just controlling a micro. Perhaps there is an occasional software glitch. It would be worth loading up a desktop instead and seeing if it still does it before delving into the Portsdown code. Mine does the opposite, it goes full brightness, very rarely and only for an instant.
