QO-100 Bullseye lnb
QO-100 Bullseye lnb
Help please what is the neck size for the QO-100 Bullseye lnb.
Cheers
Brian G6HFS
Cheers
Brian G6HFS
Re: QO-100 Bullseye lnb
40mm diameter
going to start setting up the dish and lnb for QO-100, is RG6 coax a good starting feeder or any other recommendation's.
Brian G6HFS
Brian G6HFS
The LNB puts out a huge signal so almost any sort of 75R coax will be fine. Cheap 'satellite coax' will be fine for even quite long runs. RG6 is going to be tricky to fit into an F-plug I expect.
So have managed to get a signal on my small old sky dish, going to try 80cm dish soon.
Brian G6HFS
Brian G6HFS
- CF7E6369-EFFE-4F97-BD68-F704D5085435.jpeg (593.65 KiB) Viewed 8485 times
Re: QO-100 Bullseye lnb update
Installed the 80cm dish today, may try a position tweak but looking ok at 7.1db after first alignment, the old dish was boarder line and just over 4.0db
Brian G6HFS
Brian G6HFS
- 317ADC78-105F-44D9-AC2F-358FEFE1E58E.jpeg (1.24 MiB) Viewed 8360 times
That's GOOD for a 80cm dish....
Hi Gareth,
Perhaps I should leave well alone, knowing sod’s law you will never get the same results if you start tweaking.
Brian G6HFS
Brian G6HFS
