QO-100 Bullseye lnb
g6hfs
QO-100 Bullseye lnb
Post by g6hfs » Fri Aug 12, 2022 6:28 pm
Help please what is the neck size for the QO-100 Bullseye lnb.
Cheers
Brian G6HFS
Re: QO-100 Bullseye lnb
Post by G8GKQ » Fri Aug 12, 2022 6:49 pm
40mm diameter
g6hfs
Post by g6hfs » Fri Aug 12, 2022 10:49 pm
Thankyou
g6hfs
Post by g6hfs » Sun Aug 14, 2022 2:13 am
going to start setting up the dish and lnb for QO-100, is RG6 coax a good starting feeder or any other recommendation's.
Brian G6HFS
Post by radiogareth » Sun Aug 14, 2022 6:10 am
The LNB puts out a huge signal so almost any sort of 75R coax will be fine. Cheap 'satellite coax' will be fine for even quite long runs. RG6 is going to be tricky to fit into an F-plug I expect.
g6hfs
Post by g6hfs » Wed Aug 17, 2022 5:18 pm
So have managed to get a signal on my small old sky dish, going to try 80cm dish soon.
Brian G6HFS
g6hfs
Re: QO-100 Bullseye lnb update
Post by g6hfs » Thu Aug 18, 2022 6:14 pm
Installed the 80cm dish today, may try a position tweak but looking ok at 7.1db after first alignment, the old dish was boarder line and just over 4.0db
Brian G6HFS
Post by radiogareth » Thu Aug 18, 2022 9:07 pm
That's GOOD for a 80cm dish....
g6hfs
Post by g6hfs » Thu Aug 18, 2022 11:30 pm
Hi Gareth,
Perhaps I should leave well alone, knowing sod’s law you will never get the same results if you start tweaking.
Brian G6HFS
