Ryde in repeater
DL5BCA
Ryde in repeater
Post by DL5BCA » Sun May 09, 2021 12:25 pm
Since yesterday we have built a Ryde in our DB0OV repeater.
I am connected via Hamnet and can control the Ryde accordingly.
As long as I am connected to the menu with Hamnet via the shell and set to point 0 "Receive", which Ryde also receives ..
As soon as I log off from the shell, the reception is stopped.
I think I have a mistake in reasoning, what am I doing wrong so that the reception works on when I am no longer connected?
I always have crazy ideas.
Please don't be surprised.
Re: Ryde in repeater
Post by g0mjw » Sun May 09, 2021 1:04 pm
If you log out you probably stop the processes you start.
Post by G8GKQ » Sun May 09, 2021 2:08 pm
Mike is correct.
The way Ryde is designed to work as a repeater receiver is that you should set the start-up preset to be the preset that you want. Once you have done that, then reboot, and the receiver will start itself unattended without an ssh session.
DL5BCA
Post by DL5BCA » Sun May 09, 2021 2:24 pm
Ahh.
Well, that's the right clue ...
I'm surprised how good a 2Ms signal looks ...
Now I will also add a 500kB and have it scanned.
Thank you very much, Mike and Dave.
BTW: And i am transmitting with the Portsdown.. Runs so great....
