Since yesterday we have built a Ryde in our DB0OV repeater.
I am connected via Hamnet and can control the Ryde accordingly.
As long as I am connected to the menu with Hamnet via the shell and set to point 0 "Receive", which Ryde also receives ..
As soon as I log off from the shell, the reception is stopped.
I think I have a mistake in reasoning, what am I doing wrong so that the reception works on when I am no longer connected?
Ryde in repeater
Ryde in repeater
Re: Ryde in repeater
If you log out you probably stop the processes you start.
Mike is correct.
The way Ryde is designed to work as a repeater receiver is that you should set the start-up preset to be the preset that you want. Once you have done that, then reboot, and the receiver will start itself unattended without an ssh session.
Ahh.
Well, that's the right clue ...
I'm surprised how good a 2Ms signal looks ...
Now I will also add a 500kB and have it scanned.
Thank you very much, Mike and Dave.
BTW: And i am transmitting with the Portsdown.. Runs so great....
