How to run H265 on Pluto using GTX1050Ti graphics card
G3YQC
Post by G3YQC » Thu Apr 30, 2020 3:32 pm
I’m trying to run H265 on the Pluto (with F5OEO firmware) using SQ6QV script; GTX1050Ti graphics card and vMix. I followed the instructions detailed in the BATC wiki regarding ffmpeg installation and editing the script.
I set up vMix to use External Output (as instructed in the wiki) then ran the script but Pluto doesn’t appear to transmit.
I note that by using vMix on External Output (rather than stream) there is no opportunity to set important parameters such as frequency, FEC, SR, PTT etc. So from Pluto’s virtual drive I ran the info file and chose the DATV Controller tab. I entered appropriate parameters, clicked the (almost invisible) PTT button and then clicked Apply Settings. But the screen just cleared to white and Pluto did not transmit.
Can someone please confirm that the DATV Controller screen actually works and if so, why can I not see the Pluto going to transmit?
I have searched extensively on forums, online documentation, comments on the QO-100 chat screen etc. for any clues to what I’m doing wrong but can find nothing. Any guidance on how to get this going would be very much appreciated.
Thanks John G3YQC
HB9DUG
Re: How to run H265 on Pluto using GTX1050Ti graphics card
Post by HB9DUG » Mon Jul 06, 2020 5:17 pm
Hello John,
If interested, I can explain you how to do it with OBS directly using the recording mode.
73 de michel, hb9dug
on6py-Rudy
Post by on6py-Rudy » Sun Nov 07, 2021 10:59 pm
Hi John,
I have the same probem with my gtx1050.
How didnyounresolved it, pls?
Rudy on6py
Pa3fbx
Post by Pa3fbx » Fri Nov 12, 2021 12:24 pm
You are commenting on a 1 year old topic..
Running OBS and and 1050 Nvidea shouldnt be any problem by now..
Benno
on6py-Rudy
Post by on6py-Rudy » Fri Nov 12, 2021 1:41 pm
I had problem with my gtx 1060 driver. Only since yesterday NVidia’s most recent update it is solved and rx and tx work fine on one pc!
Thank you, Nvidia. ;-)
