ATV on 6cms - It's Cheap and Easy on 5665MHz
G8JAN
Re: ATV on 6cms - It's Cheap and Easy on 5665MHz
Post by G8JAN » Mon May 14, 2018 9:17 am
Hi guys I'm looking for a simple 5 Ghz field strength meter. I've seen a couple of circuits on the net but none of the recommended diodes appear to be available! I can't find anything ready made on Fleabay apart from one device from the states at around £21 plus postage!
A type and source of a suitable signal diode would be useful.
Post by radiogareth » Mon Jun 18, 2018 12:09 pm
I know I've missed the activity weekend (business got in the way) but I have an opportunity to operate from Detling Hill next Saturday if anyone has a good path to it. I have a pair of flat plate aerials and a decent surveyors tripod and 2 watts. Just need to wire it all up to 12 volts.
I can have 2M talkback too.
Anyone likely to be around?
Latitude: 51.2983 , Longitude: 0.587641
Grid Reference : TQ 804586, QTH Locator: JO01hh
M0TFO
Post by M0TFO » Tue Jun 19, 2018 9:07 am
Morning all, I've been searching for the Tarot 5.8G modules without success, have alternatives been found/used since the original post, I've seen a few modules rated at 1w but lack any useful spec, could you point me in the direction of a seller that has the Tarot or an alternative.
M0TFO
M0AYF
Post by M0AYF » Tue Jun 19, 2018 1:55 pm
After reading all the posts in this thread (and if I understand correctly) we have a number of possible options for TX equipment. The 600 mW units, the PA's that will "boost" the 600 mW output to around 2 Watts and more recently 1 Watt tx units.
From earlier posts and links to members web-pages it seems the 2 Watt PA units can be somewhat "fragile" if not treated with care. Are the 600mW and 1 Watt varients just as fragile?
My current thoughts are to buy a couple of the 600 mW transmitters and a pair of receivers to evaluate but as the market place keeps changing I am finding it difficult to decide on the best choices currently offered on ebay.
So I should like to ask if anyone can point me towards a current supplier of tx equipment on ebay which has been shown to be successful and also any tips on preventing the tx from expiring :-) I understand a good heatsink and fan are a wise precaution but does anyone know how sensitive these units are to supply Voltage and static damage etc.
73,
Des (M0AYF)
M0SKM
Post by M0SKM » Tue Jun 19, 2018 9:39 pm
M0TFO
Hello Rob,
My Tarot TX/RX units (TL300N) came from AliExpress and they still sell them; though not at the £14.00 I paid.
They also seem to be housed differently, the TX was in an aluminium case which was easy to heat sink.
https://www.aliexpress.com/item/Tarot-T ... autifyAB=0
73 Steve
M0TFO
Post by M0TFO » Wed Jun 20, 2018 6:21 am
Thanks Steve...
Post by g8gtz » Wed Jun 20, 2018 8:44 am
I had an email from Barry G8AGN yesterday which may be of interest:
This is what I'm using at present and it seems to be OK. I have two of them and both give about 1.7w out.
https://www.ebay.co.uk/itm/2000MW-5-8G- ... 2749.l2649
My only criticism is that the fan is a bit noisy but I can live with that. One advantage of the module is that it has a built-in electret mic and speech amp. I removed the mic and now use a remote one with very good results.
I have read somewhere that these Tx modules come in two versions. The higher power one, such as mine, has multi-coloured wires connecting the RF and control boards whereas the lower power one has only red wires.
73 Noel - G8GTZ
M0TFO
Post by M0TFO » Wed Jun 20, 2018 9:04 am
Looks like the listing has expired and takes you to an alternative (Rx) unit. Do you have a fresh listing or model number?
M0TFO
Post by M0TFO » Wed Jun 20, 2018 9:12 am
I'll email Barry...
Regards.
M0SKM
Post by M0SKM » Wed Jun 20, 2018 10:11 am
73,
Des (M0AYF)
This setup works for me and produces 3.9 Watts at the N connector.
Tarot TL300N screwed to double sided copper clad board; PA tack soldered to same board. Copper clad board bolted to diecast box with a dab of heatsink compound between.
Holes drilled top and bottom of diecast box to work as a chimney.
73 Steve
