Open Tuner 0.1 - Test Version
Basil
Re: Open Tuner 0.1 - Test Version
Post by Basil » Thu Mar 30, 2023 1:56 pm
Thanks Martin, just tried that but it doesn't work for me. Open Tuner eventually opens, but any attempt to untick the relevant box just brings up "Not responding". I suppose it needs a time out to fail more elegantly, but that's rather nit picking.
What I would like is an option to put the MER of the beacon on in the fullest screen size, so I can turn the monitor towards the window and then furtle about with the dish and be able to see what's occurring. Might not suit many and certainly not all setups, but would be ideal for mine ;)
Best regards,
G8KOE
Post by G8KOE » Thu Mar 30, 2023 2:28 pm
Give it a bit longer before trying .
It is a bit slow to respond but will eventaly.
Martin
G8KOE
zr6tg
Post by zr6tg » Fri Mar 31, 2023 6:23 pm
zr6tg wrote:
Mon Mar 27, 2023 6:50 pm
arthur21 wrote:
Mon Mar 27, 2023 6:47 pm
Thanks you all for the suggestions.
My VLC is the 32bit version.
My Serit tuner is one of the early ones which I suspect does not have the LNA .
Is there a way around this problem without having to change the Serit tuner
Arthur G4CPE
Yes, I'm sure it should be possible to make the software smarter to deal with it. Arthur can you drop me your email via a pm. I'm away for work for the rest of the week, but when I get back then I'll trouble shoot it with you.
Hi Arthur, I have sent you an email with a test version that allows you to disable the LNA initialization as a test to see if your problem is LNA related.
73,
Tom
zr6tg
Post by zr6tg » Fri Mar 31, 2023 6:24 pm
I'm adding a new option to disable the qo100 related items from the commandline for the future. Its coded in and will be in the next release sometime over the weekend :)
Added to the list
arthur21
Post by arthur21 » Fri Mar 31, 2023 7:03 pm
Hi Tom
Thanks for the test version for no lna. I have just installed and run the program but with the same result it does not complete the setup, the last few lines are still init LNA TOP Flow LNA init 1 How do I start it with DISABLELNA my PC Knowledge is very poor
73 Arthur
G4CPE
arthur21
Post by arthur21 » Fri Mar 31, 2023 7:40 pm
Hi Tom
Sorted it works fine with the shortcut properties edited
I had to get Google to help. I learn a little bit every day the trouble is I forget it the next day Hi
Thanks Tom it runs well now
73 Arthur
G4CPE
zr6tg
Post by zr6tg » Sat Apr 01, 2023 4:23 pm
New Version: 2023/04/01
LO Limit Fix
High Freq Crash Fix
Aspect Ratio Force (Right Click on Video Playing)
Frequency Manager
Spectrum: Over Power
Command Line Parameters (DISABLELNA, DISABLEQO100, AUTOCONNECT)
Windows position/size save on exit
Misc smaller Fixes
https://www.zr6tg.co.za/open-tuner/
zr6tg
Hi Tom
73 Arthur
G4CPE
Hi Arthur,
Glad to hear :) I'll add it in the settings in next release, but for now you can use the shortcut to disable lna init.
zr6tg
Post by zr6tg » Sat Apr 01, 2023 4:24 pm
g8ayc wrote:
Wed Mar 22, 2023 4:43 pm
Brilliant piece of software. I tried to set it to receive 2408.25 with a 0 LO offset but it didn't like it. Even setting it to 2408 gets rejected.
Nigel G8AYC
This should be sorted now Nigel, please test and let me know :)
T
Basil
Post by Basil » Sun Apr 02, 2023 1:02 pm
Thanks for the further update Tom. AUTOCONNECT is working fine and a useful addition, but I am unable to get it to save the window size and position on exit. Is there a command line instruction for it, or some other means of forcing this? Thanks Tom!
Best regards,
