Portsdown 4 - New Update 202008050
G8IKP
Re: Portsdown 4 - New Update 202008050
Post by G8IKP » Thu Aug 13, 2020 4:16 pm
Hello Dave I was really enjoying the P4 receive capability with mintioune but since the 2020008050 update I cannot resolve any pictures from the beacon. I get good lock and MER of 10db but all of the players do not seem to resolve video any more, only sound on some. I do get video from some other stations at different SR's. Do you recommend I do a new build ? I also tried forcing the update again. John G
Post by G8GKQ » Thu Aug 13, 2020 4:29 pm
Hi Wolfgang (and Alain)
Thanks for prompting me on this one. I have found the problem - it hangs if there is no Pluto connected.
The fix will be in the next update but if you want to do it now, simply amend line 127 of rpidatv/scripts/scheduler.sh to read:
      timeout 2 sshpass -p analog ssh -o StrictHostKeyChecking=no root@"$PLUTOIP" 'reboot'
Sorry - my test/development rig has the Pluto permanently connected, so I did not find the problem until I took it all apart.
Post by G8GKQ » Thu Aug 13, 2020 7:32 pm
Hi John G8IKP
Sounds like a problem with VLC. Probably best cured by a card rebuild.
G8IKP
Post by G8IKP » Sat Aug 15, 2020 8:20 am
Thanks Dave I will try the rebuild and report back. John
VK3IE
Post by VK3IE » Sat Aug 15, 2020 8:31 am
Greetings
PI 4 with Pi Camera V2 installed in a Smarti Pi Touch 2
I thought it was OK the Portsdown when first ran was UPSIDE, for us folk Down Under :) found the Invert screen all good.
The image produced by the PI camera V2 now has me sideways.
The camera mounts one way in the case curious if there is an option to Rotate the image/camera..
Thank You
Post by G8GKQ » Sat Aug 15, 2020 10:16 am
A quick search would have brought you to this Forum Topic about the sideways camera: viewtopic.php?f=103&t=6747
VK3IE
Post by VK3IE » Sat Aug 15, 2020 9:58 pm
Thank you,
Thinking there may have been a a possible Software/solution
Look forward to more of your excellent work on PD4
G8IKP
Post by G8IKP » Sun Aug 16, 2020 6:37 pm
That fixed it the SD rebuild. Thanks Dave for all your amazing work. John
g6crf
Post by g6crf » Wed Aug 19, 2020 6:41 pm
Hi Dave, After updating to this release I have tried to get the PI-cam working but get no output from the Pluto. It still works fine for the testcard but nothing from any other source.
I also tried the dev version but that was no better.
Should I try a rebuild from scratch?
Cheers
Terry
Post by G8GKQ » Wed Aug 19, 2020 8:17 pm
Hi Terry
I think that the experimental Pluto code might need to have a USB audio dongle connected for the Pi Camera to work. Please let me know if you have one connected?
I can look at working round that requirement in future.
