Langstone Update
Re: Langstone Update
Post by radiogareth » Sun May 10, 2020 4:02 pm
Just had my first two-way (RX-TX my end) SDR QSO, across town with Martin G4FKK. My Langstone driving a small amp, driving a brick amp and filter hooked up to my 5 element LFA pointing in his direction (not a good path).
Happy enough to now do some shack tidying ;-)
Post by g4eml » Mon May 11, 2020 5:16 pm
A couple of new Updates today.....
Changes to the GUI..
Added Tx Attenuator control to the settings menu. Different settings can be made for each band.
Likewise Squelch level and FFT Reference level are now linked to the band selected.
Changes to the SDR..
SSB Tx now has ALC. This prevents overdrive and improves Tx Level control. It is not as good as a proper speech processor but it helps.
CW Tx signal quality improved by extra filtering.
Colin G4EML
G1LPS Terry
Post by G1LPS Terry » Mon May 11, 2020 6:21 pm
Nice update.
I noted that there is no noticeable delay in the tx audio now also.
Speech seems to happen instantly.
Great work :D
Post by g4eml » Mon May 11, 2020 7:43 pm
The latency (delay) with tx speech is still there. It gradually increases the longer the program is running. I have a few ideas that might fix it.
Post by radiogareth » Tue May 12, 2020 7:50 am
If I want to update, I assume its rebuild the flash card as per the initial instructions? However, formatting the disc shows only one 50Mb drive which Windiskimager clearly says isn't large enough.
From memory I have to go into windows disc management and delete the 50Mb volume, then the larger one, then reformat etc...
Well, that's what I'm doing now......not a Linux expert ;-)
Post by G8GKQ » Tue May 12, 2020 8:47 am
Probably too late for you now, but updates are a lot simpler than that. See this Wiki page: https://wiki.microwavers.org.uk/Langstone_Project
Post by g4eml » Tue May 12, 2020 9:54 am
Hi Gareth,
As Dave says you can update as follows;
Log into your Langstone using SSH,
cd Langstone
./stop
./update
./run
See the notes in the WiKi if you have changed your Pluto’s IP address. (Thanks Dave for those notes)
A completer rebuild will do the same but is not necessary.
Windiskimager doesn’t normally need the card to be reformatted. It will work with an unformatted card or one that already contains data.
As you have found Windows can’t see the larger second Linux partition so it gets confused regarding disk sizes.
Post by radiogareth » Tue May 12, 2020 11:09 am
Thanks both, sorted two things now :-)
Quick route to rebuild - great :-)
Still had trouble during the build despite trying different PSUs (again). Took it all downstairs to the actual main Virgin router, plugged it into a spare port and it went through like a dream. So flakey network switcher in my loft room seemed to have been dropping packets, or something.....
Anyway, now working like a charm again :-)
Post by g4eml » Tue May 12, 2020 11:35 am
As Dave has found with the Portsdown, a poor internet connection can cause problems with large installs.
It is difficult to write an install script that can handle that.
g0uhy
Post by g0uhy » Tue May 12, 2020 3:35 pm
Hi Colin,
I've just done a new SD card and now my screen is upside down. When I first loaded the software I remember changing a file to reverse this but can't remember how I did it...hi. Any help gratefully received.
Malcolm G0UHY
