Bringing a Pluto back to life
G8KOE
Re: Bringing a Pluto back to life
Post by G8KOE » Wed Mar 15, 2023 5:56 pm
Hi John,
Try changing the USB lead.
You may be using one that only delivers the power.
73's
Martin
Post by g0mjw » Wed Mar 15, 2023 7:05 pm
G1ORP wrote:
Wed Mar 15, 2023 5:12 pm
Hi Mike, Have installed but no change?
John
What does it say in Device manager?
Basil
Post by Basil » Wed Mar 15, 2023 7:13 pm
It sounds like it may need an attempt with JTAG and the Xilinx software to try and resurrect it. It's a tricky route but has worked for me a couple of times. Some investment in hardware is needed, but not software. The info is there on the Analog Devices forums.
Best regards,
G1ORP
Post by G1ORP » Thu Mar 16, 2023 10:10 am
Good morning,
I have tried using two USB leads, not difference.
Device Manager, under Universal Serial Bus Controller, No hint of Pluto.
The strange thing is from a network point of view it all looks OK.
Is it possible to install all types of programs via SSH?
Hopefully I won't have to go down the jtag? route .
Thank for all your answers,
John
EA7KIR
Post by EA7KIR » Thu Mar 16, 2023 10:18 am
If I recall correctly, and you are logged in to the Pluto via ssh, you can download firmware directly onto the Pluto using the wget command.
Michael EA7KIR
G1ORP
Post by G1ORP » Thu Mar 16, 2023 10:44 am
Good morning Michael,
Thanks for the info will have a play, BTW I did`t get a chance to thank you for your help the other day.
John
EA7KIR
Post by EA7KIR » Thu Mar 16, 2023 11:00 am
In fact, it's also possible to copy local files on your PC to the Pluto using the scp command.
Michael EA7KIR
G1ORP
Post by G1ORP » Thu Mar 16, 2023 11:30 am
Does that mean that not having a working USB connection is no big deal?
Post by g0mjw » Thu Mar 16, 2023 12:08 pm
I still think your problem is drivers on the PC. If it works with the ethernet adapter then the Pluto is fine. You don't need to use USB on the PC unless you need to.
Post by G8GKQ » Thu Mar 16, 2023 12:37 pm
Have you tried connecting this Pluto to a Portsdown? If not, I'll move the topic to the "Digital ATV" section of the forum.
