Problems getting VMix DATVEasy Pluto to work
Rishtonite
Re: Problems getting VMix DATVEasy Pluto to work
Post by Rishtonite » Sun Oct 05, 2025 7:44 pm
g3uis wrote:
Sun Oct 05, 2025 4:48 pm
Rishtonite wrote:
Sun Oct 05, 2025 4:01 pm
Tony, the problem is my PC is on a 172 network, not 192.
Looks like I need a PC on 192 (and currently don't have one high enough spec to run VMix)
Shouldn't matter . Just try it using USB. It will just work !!!
Tried that. It can't get it to work. I have a feeling that the issue is DATVEasy not communicating with VMix because of the 172/192 network address issue.
For now I'll just continue to use the Portsdown4 and hopefully find a Fuschicai EasyCap which I can connect to my VHS/DVD Recorder/Player
Barry
g3uis
Post by g3uis » Mon Oct 06, 2025 12:48 pm
Um. Are the DATVeasy and Vmix not on the same PC ? As they would communicate over the Bus not IP ?
Rishtonite
Post by Rishtonite » Mon Oct 06, 2025 8:37 pm
Yes they are on the same PC. DATV Easy connects to 192.168.2.1 and clicking Start+ it shows 2 green lights and high kb/s and Adalm Pluto Output GPO-0 turns green, so I'm assuming that is a signal coming from VMix, but I get no RF out.
In VMix I have External in use (red) and a video playing in the right hand screen. In Outputs I have 1 Output, Input 1
Barry
Post by g0mjw » Mon Oct 06, 2025 8:54 pm
Are you sure there is no output? Could it be there is but it is at a very low level or not on the frequency you expect?
Rishtonite
Post by Rishtonite » Mon Oct 06, 2025 9:13 pm
The Pluto works when used in the Portsdown and gives me 2 watts out on 1249.000. DATEAsy is set to TX Gain 87%, Max 100%
Post by g0mjw » Mon Oct 06, 2025 10:29 pm
But you didn't answer my question so I am not sure how we can help more. I asked if you were sure there was no output. Not if it works with a different piece of hardware that uses a very different means of generating the RF. I think maybe there is RF but at a very low level. You can tell if the Pluto is getting the transport stream from the analysis tab. You showed that earlier, so I assume that is working.
Screenshot 2025-10-06 232632.png (188.43 KiB) Viewed 3943 times
If that is there, the video is getting to the Pluto. As long as the Pluto PTT is active, there will be RF coming out.
g3uis
Post by g3uis » Tue Oct 07, 2025 8:39 am
2 watts out of a Pluto !!
Rishtonite
Post by Rishtonite » Tue Oct 07, 2025 9:41 am
Pluto plus a small amp purchased from Banggood. That's connected in both the Portsdown and VMix/DATVEasy setups.
Rishtonite
Post by Rishtonite » Tue Oct 07, 2025 10:06 am
[snip image]
1. I'm unsure where to find that transport stream analyser software to check.
2. I find the DATVEasy 3.08 PDF instructions lacking in detail. In the section on PTT/Output it shows USB HID relays but no explanation of where they are physically connected and how it interacts with Pluto.
Reading between the lines I'm now assuming one of those relays is essential??
g3uis
Post by g3uis » Tue Oct 07, 2025 11:42 am
No relays required.
My setup. PC on 10.0.0.x subnet. Pluto plugged into USB. OBS with virtual camera plugin. Worked first time.
