DATV Express ODROID and PC
N6GKJ
Post by N6GKJ » Mon Oct 12, 2015 7:01 pm
Hello Guys!!,
I have an issue to be resolved. Right now I don't see any process that when DATV Express is launched that the transmitter can come up running.
I want to use my DATV Express board as a DATV repeater Exciter, can I get a check box near the "PTT" bar on the main page that once checked, it puts the transmitter into TX mode? at that point tx on or off can be controlled from the header pin. This check box status would be remembered.
Another way to do this is with a software switch that could be used in conjunction with the launch command:
i.e....
DATV Express -t
This could be used to tell the software to turn on transmitter as soon as it comes up.
The need for this is obvious, if you loose power, you must manually key the PTT bar in the application to turn on TX, at a repeater site we will have to make a trip there to do this....
Unless I missed something and this is an existing undocumented feature... I have been known to miss the obvious!!
73,
Ron
73,
Ron....
N6GKJ CM98ic
