Guide to setting up live stream on batc.tv
Post by g8gtz » Sun Jun 22, 2014 2:39 pm
A quick guide on how to set up the Adobe Flash media encoder to stream to batc.tv is available here:
http://www.batc.org.uk/Getting_Started/streamguide.pdf
Re: Guide to setting up live stream on batc.tv
Post by g8gtz » Thu Oct 01, 2015 9:00 am
Further to the guide - your url and stream name are found as follows:
When you have logged in at http://www.batc.org.uk, go to "manage streams" and you will see the following - the url and stream name you require is listed at the bottom of the page.
Post by g8gtz » Tue Jan 26, 2016 10:45 am
Had the question "whats a short url and where do i get one?"
The short URL is a short cut to your streaming channel and is listed on the manage my stream page (as shown below) or published by stream owners on their website site or streaming page.
short url.jpg (66.24 KiB) Viewed 9170 times
For example to use this short URL, type http://www.batc.tv/streams/g8gtz into your web browser, where g8gtz is the text you entered in the "Short URL" field above.
Return to “Streaming”
