HAM-Video from the ISS
Re: HAM-Video from the ISS
Brilliant well done Colin.
On a pass yesterday morning 3 stations in France and Italy managed continuous reception for 7.5 minutes. Now that you have all proved it is receivable it's probably time to start thinking about how we can use signaling to aggregate the signals together to provide automatic handover between stations, thereby providing longer coverage for schools etc....
Tutioune has lock indication and the BATC could host the facility, we just need someone to work out how to do it and write it! There's a challenge for someone!
No problems with the 2Ms/S.
Managed to still have a picture at 1300KM range this morning.
- 2nd 2MS.jpg (141.72 KiB) Viewed 10906 times
ISS has changed to 2369 MHz 1.3 MS/S
Good results here
Good results here
Fantastic results today.
Received my first live video from the ISS.
I will post in BATC film archive when I can do a better .flv conversion, meanwhile its on https://www.youtube.com/watch?v=61GTGTOa8AE
Colin
Colin
- ISS still2sw.png (298.13 KiB) Viewed 10828 times
Excellent result Colin, Ive been outside past few nights watching it whizz by overhead, very clear flight across the sky up here in IO83, appeared bang on time to the prediction path on ISS spotter on Ipad, was at 63 deg azimuth last night so would have been good to try some 13cm datv RX, no gear here unfortunately.
Jean Pierre F6DZP and his XYL have been on the main French TV channel TF1 see the report here
http://www.wat.tv/video/son-salon-il-di ... eyxv_.html
This is just what we need to encourage more people into the hobby.
Well done.
Colin G4KLB
Well done.
Colin G4KLB
Well Colin, your mission is to get on South Today!
There's a problem with that Charles - South today is only a 25 minute program and Colin's single overs are longer than that!
It would have to be a 1 hour Horizon special
Yes that is true, still the BBC do have a history so it might be worth a try
https://www.youtube.com/watch?v=eRfeHl31JAk
There's always the red button for extended overs.g8gtz wrote:There's a problem with that Charles - South today is only a 25 minute program and Colin's single overs are longer than that!
