World first DVB-T RTX on 434.500 with 2MHz bandwidth
oe7dbh
Re: World first DVB-T RTX on 434.500 with 2MHz bandwidth
Post by oe7dbh » Sun Jun 23, 2013 4:21 pm
Photo...
oe7dbh
Post by oe7dbh » Sun Jun 23, 2013 4:23 pm
Photos... part2
oe7dbh
Post by oe7dbh » Tue Jul 02, 2013 3:04 pm
Standalone 70cm DVB-T transmitters HV-100 in test....
more Pictures on http://www.oe7forum.at/viewtopic.php?f= ... t=30#p1110
Freq.range: 50MHz to 950 MHz ( Future Dualband version 50~950MHz and 1200~1350MHz )
Bandwidth: 2MHz to 8MHz
Resolution: MPEG2 and H264
Output: max. 5dBm
Input: CVBS or HDMI
available beginning August.
Price 560,00 US$
Order by http://www.hides.com.tw
G8XZD-TV
Post by G8XZD-TV » Wed Jul 03, 2013 6:24 pm
Looks good will be interested to know how you get on - any news of a European source for these units?
73 Ian
oe7dbh
Post by oe7dbh » Sat Jul 13, 2013 3:18 pm
New amplifier for DVB-T transmitter developed.
more photo: http://www.oe7forum.at/viewtopic.php?f= ... t=30#p1118
Bild 056a.jpg (345.92 KiB) Viewed 11884 times
on4bhm
Post by on4bhm » Mon Aug 05, 2013 7:21 am
I received my UT100 last friday.
is is the version with tx only.
i manage to tx my desktop. but when i try to transmit my webcam, he fails....
any other source than my own desktop fails... :(
i'm using windows7 32bit sp1
have you managed to use the dongle on linux?
kind regards
ON4BHM
Guy
oe7dbh
Post by oe7dbh » Thu Aug 08, 2013 11:02 am
Hi Guy ----> look my post on OE7 Forum....
New Test with DVB-T Sticks.... http://www.oe7forum.at/viewtopic.php?f= ... t=30#p1139 TX Part DUALBAND 70cm and 23cm !!!!
Technik: http://www.oe7forum.at/viewtopic.php?f= ... =105#p1141
HomeMade: http://www.dl1mfk.de/Sonstiges/Darko/index.htm
pe5jw
Post by pe5jw » Thu Aug 08, 2013 1:23 pm
Hello everyone, this is my first posting here.
I recevied the ut-100c tuesday.
Using windows 8, desktops streaming is working now, tsplayer didnt work for me but so many settings i probably have some wrong :)
I used 8mhz direct connection to a tv now i would like to use smalband 2 mhz on 70cm but i dont have a receiver for it.
(tv skips channels 13 to 20 and only does 6/8 Mhz).
Is there a way to use a usb dongle( i have serveral rtl2832u dongles) on 2mhz 70cm, the dvb-t programs i have do not have the settings for it.
I think i received the old software how can i tell the difference ?
'73 Joeri, pe5jw
oe7dbh
Post by oe7dbh » Mon Aug 26, 2013 3:38 am
..... ich denke das DVB-T Stick mit RTL2832 nicht empfangen kann Signale mit 2 , 3 und 4MHz , mindestens hat bei mir nicht funktioniert, auch nicht
mit spezielle offene software ( auf 435MHz empfangen JA aber Bandbreite NEIN ).
Schau mal auf Tiroler Forum: http://www.oe7forum.at/viewtopic.php?f= ... t=30#p1139
PC2TV Soft neueste Version Nr.: newest version v1.0.1.7
pe5jw
Post by pe5jw » Sun Sep 01, 2013 6:14 pm
Hallo Darko,
Yesterday the ut100d arrived so the experiments on 70cm can start :)
(also came with the 2.2 verion of the cd)
Your probably right about the bandwidth.
But the rtl2832 can do 23cm 6/8 mhz when using a modified driver.
In Linux it can be done by recompiling te driver using a adapted file were the max_receiving frequency is set above the 23cm band (Standaard is 862 Mhz).
A windows driver mod could do te trick also but i don't now how to do that.
If anybody knows how please share it.
