GPIO input to change Ryde F type input
g8lce
Post by g8lce » Sat Nov 15, 2025 4:24 pm
Is there any chance of a version of Ryde software where a GPIO input could switch the frequency and input F type so that a repeater controller could switch between frequencies and aerials? This would allow a repeater to experiment with different frequency inputs without a great expence or modification. For example on GB3NQ we have 2m, 70cms, 23cms, Oscar 100 and a stream input. As an experiment one of these inputs could switch between say Oscar 100 and 71Mhz or 13cm etc. at certain times. If the experiment worked then another Ryde etc. could then be built.
g8lce
Re: GPIO input to change Ryde F type input
Post by g8lce » Wed Nov 19, 2025 10:09 am
I am wondering if the Ryde GPIO pins PWM0 and PWM1 are inputs or outputs and weather they will be working? The wiki says 'Note that Band GPIO setting does not have any effect yet.'
If they were inputs to control the band selection this would answer my idea to control an experiment input to a repeater. Looking into the Ryde manual the idea could use the 8 way switch controller as well which opens another door for experimentation!
Pa3fbx
Post by Pa3fbx » Thu Nov 20, 2025 11:35 am
Hi, I am working a similar problem.
I was going a different way as my remote controller is working on node-red.
And Tom proved that you can send ip messages to ryde controlling several bits and pieces.
This includes preset channels witch is what you would want for this.
But i am still struggling on the messages format, i should send.
The band selection pins are output as i am using that on a different project.
Benno
g8lce
Post by g8lce » Fri Nov 21, 2025 9:23 am
The other way to attempt this would be to use a Portsdown in console mode - so no screen attached - and control the Receive section and config part to change the input a or b. If you can work out the network control inputs needed ( mimicking the remote control from a windows computer to control the Portsdown in console remote mode ) it would be easy!!!!!
This would allow repeaters with Minitiouners and Rydes to change the Ryde SD for a Portsdown SD and reprogram the controller then be able to double their input frequency channels or aerials. Not at the same time but there would be uses which people have not thought of yet.
This does stop the scanning features of the Ryde but in one case I am looking at it would be ideal. On GB3NQ the fixed Oscar 100 input could on a timed rota switch to 71MHz 333kSR (for experimenting)
Post by G8GKQ » Fri Nov 21, 2025 10:14 am
They Ryde receiver can already switch between the top and bottom input F types for different bands.
Edit /home/pi/ryde/config.yaml and set up the band with TOP or BOTTOM:
    QO-100: &bandlnblow
        source: LONGMYND
        lofreq: 9750000
        loside: LOW
        pol: NONE
        port: TOP
        gpioid: 7
    146: &band146
        source: LONGMYND
        lofreq: 0
        loside: SUM
        pol: NONE
        port: BOTTOM
        gpioid: 1
I haven't tested the GPIO switching mentioned in the config file but I'll ask Tim this weekend.
Far easier to do it with the Ryde which was designed for the purpose than the Portsdown.
Pa3fbx
Post by Pa3fbx » Fri Nov 21, 2025 6:58 pm
Yes Dave, but the question was to have a single gpio pin input to select a preset or channel.
So gpio is high. is channel x on port A and GPIO low is Channel Y on port B.
Benno
