125kB not decode?
125kB not decode?
I'm experiencing a strange issue with the Ryde receiver at our repeater location.
I access the Ryde via Putty and wanted to add additional bandwidth (125 kB).
333 kB and 1000 kB work without issues.
Now I go to menu 4, Presets, and select 8, 437.0 MHz_1000 preset.
Then I select the 437 MHz band and enter the frequency 437500 kHz.
Then I select "Scan SRs Set Multiple Receive SRs for Scanning" and enter "125" - OK - "333" - OK - "1000" - OK, and then leave the 0 so that no further SRs are saved.
Then "Receive."
Unfortunately, the 125 kB aren't being decoded. Also 500kB aren't decoded.
What am I doing wrong?
73 Thomas DL5BCA
Then "Receive."
73 Thomas DL5BCA
I always have crazy ideas.
Please don't be surprised.
Re: 125kB not decode?
Probably there is a frequency offset in the NIM so it isn't locking onto the narrow signal.
You could try a longer Tuner Timeout for 125kB see https://wiki.batc.org.uk/Ryde_Software# ... nsole_Menu
"The scan rate is normally 5 seconds per setting. So if you have one frequency and 4 SRs, each SR is checked every 20 seconds. If you have 4 frequencies and 4 SRs, all combinations are looked at, but only once every 80 seconds. The scan time (Tuner Timeout) can be set in the Advanced Settings. Note that a Tuner Timeout of 10 seconds is normally required for the reception of 66kS signals as they take longer to lock."
Thanks for the answers.
I forgot to mention that if I only enter an SR, for example, 125kb or 500kb, it doesn't decode either.
I think it must be something else.
It works great with 333kB and 1000kB. I would have liked to have added the 125kB.
73 Thomas DL5BCA
73 Thomas DL5BCA
See above
Hi Thomas
There are limitations with the ssh console menu script.
Please look directly at the file /home/pi/ryde/config.yaml and try editing it to achieve what you want to.
Dave G8GKQ
Dave G8GKQ
I have no problems decoding 125 nor 500 with the Ryde at our local repeater.
But when i modify the settings in our repeater, i modify always the config file..
I use FileZilla to download, make a copy and upload the config and restart the Ryde.
I use Notepad++ because its very good possible to damage the config with a blank or . on the wrong spot.
In the config file you also edit the startup preset.
So you modify a different preset and edit the startup preset.
Best regards
Benno
Best regards
Benno
