I have also been doing further tests with similar results to yours, see below. The difference being that I still don't have a picture on either of my batc receivers and no rf detected in bandviewer!
DATV-Easy
Re: DATV-Easy
Well that is clearly working. I assume the PTT is enacted ? (Quite important) You can check on the pluto web page. You can also check the power slider, frequency etc.
At this point I would check for broken SMA leads or reverse-polarised SMA leads.
