SDR Television
Re: SDR Television
Of SDR Television when running - there is a screenshot icon top left.
Re: SDR Television
Before I upgrade PC and obtain Windows 11 does anyone have a link to download SDR Television.
Many thanks
Vincent M0LCR
Many thanks
Vincent M0LCR
Re: SDR Television
Follow instructions, install sdr console then sdr telivision, also read the manual as definitions need installing for your pluto etc are required.
https://www.sdr-radio.com/sdr-television-beta-1
Re: SDR Television
Screenshots attached Mike
Tony
- SDR TV Running
- Screenshot-2025-04-26-172456.jpg (733.28 KiB) Viewed 6483 times
- SDR TV Running
- Screenshot-2025-04-26-172326.jpg (748.05 KiB) Viewed 6483 times
Re: SDR Television
Looks like you are tuned to the beacon with a 960kS sample rate, which won't work. Try 2.304 MHz.
You have the gain set to manual rather than automatic
Fix those and try again.
Re: SDR Television
Many thanksg6hfs wrote: ↑Sat Apr 26, 2025 3:54 pmHi,
Re: SDR Television
Looks different, but nothing decoded and nothing in the constellation window ?
Tony
Tony
- Latest
- Screenshot-2025-04-27-104807.jpg (747.98 KiB) Viewed 6244 times
Re: SDR Television
Can you scroll down the receive pane. you are not showing us all the settings. It looks to me like you have a strange setting for RX bandwidth. Why have you set it to 83%>
Remember, please try to give as much information as possible, log files etc.
Re: SDR Television
Thanks so much Mike
I've set everything RX wise the same as your screen shot. Also now attached the log from this session and another screenshot.
thanks
Tony
thanks
Tony
- Log.zip
- Logs
- (11.32 KiB) Downloaded 246 times
- Screen Shot
- Screenshot-2025-04-27-142744.jpg (773.96 KiB) Viewed 6129 times
Re: SDR Television
You have a SR of 1000 set but the beacon is 1500
