GB3JT Site
Locator: JO00HV
Repeater is Work in Progress. Operational TX 24/7 Omni Slot.
TX Output Digital 1318 MHz DVB-S 4 Msymbols 1/2 FEC
RX Input Analogue 1249 MHz Analogue
RX Input Digital 1249 MHz DVB-S 4 Msymbols Auto FEC
RX Input Digital 437 MHz DVB-S 2 Msymbols Auto FEC (WIP)
Talkback: GB3HE or Echolink 71066
Website: http://www.rilges.org.uk
Stream: http://www.batc.tv/streams/gb3jt
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Fri Apr 25, 2025 9:52 pm
While looking at ETCC web page... I noticed JT had gone from being with ofcom for frequency allocation.... and has now reverted back to ETCC for venting... any updates to as why .... thanks steve
Steve G4HTZ
PORTSDOWN and a RYDE …
G8PUO
Re: GB3JT Site
Post by G8PUO » Mon Jun 02, 2025 3:04 pm
Hi Steve, Pass on the information, have not been able to keep abreast with this.
However, TODAY, I have just received the NoV email from Ofcom. NoV backdated to December 24 for some strange reason.
Will try to contact the site owner this week to establish the state of play in moving forward.
KR Dave
G8PUO
Re: GB3JT Site
Post by G8PUO » Mon Jun 02, 2025 3:15 pm
#NeedToGetAWorkingPartyTogether in due course.
Although it should be fine, if anyone is free to give the repeater TX a look over, then that would be appreciated. Plan to use the original TX for now and then add bells and RX, once it is up with a test page.
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Mon Jun 02, 2025 4:24 pm
Great news Dave …yes it’s a bit strange how the NOV system works …well to me anyway
Hopefully you can get permission from site owner …and drum up some local help ….
I would probably have to /P to see it …as I’m in north Essex / Suffolk border
Not sure if your planning on having 70cms input at some point
Regards
Steve
Steve G4HTZ
G4GHD
Re: GB3JT Site
Post by G4GHD » Mon Jun 02, 2025 5:26 pm
Excellent news Dave. Unfortunately I'm not in a position to assist directly from SE Essex (no vehicle), but look forward to receiving it and giving any feedback when needed.
G8PUO
Re: GB3JT Site
Post by G8PUO » Tue Jun 03, 2025 4:04 am
70cm Input is an option. The site does have a 70cm voice repeater on it but I believe I do have some cavity notch filters in the workshop, so I can tune these if needed- for the future.
Re: GB3JT Site
Post by g0mjw » Tue Jun 03, 2025 8:01 am
As there is a 70cm voice repeater present, it may well have its own input just below 435 MHz so I think all you will need is a band pass filter to keep out the TX and other signals. The repeater TX will probably have a cavity filter on it to avoid the TX noise interfering with the RX which will do the same for your RX. A notch filter is not sufficient because of all the other signals hitting the front end of the tuner., mobile phones, TV repeater output, etc, You gain a few more dB isolation from the TX with horizontal polarisation for the DATV.
Return to “GB3JT”
