Picotuner versus Minitiouner question.
Basil
Post by Basil » Sun Apr 06, 2025 10:00 am
I have a friend who fancies receiving DATV off the QO100 satellite. I use a Minitiouner with two modules whose number I forget to allow simultaneous reception of two transmissions when paired with Open Tuner software.
I seem to recall, perhaps wrongly, that the PicoTuner has some limitations compared with the earlier Minitiouner. Was it an inability to decode some symbol rates? He wants to know which type of receiver is best to build and I am not au fait enough with PicoTuners to advise him. Thanks.
Best regards,
Re: Picotuner versus Minitiouner question.
Post by radiogareth » Sun Apr 06, 2025 10:12 am
PicoTuner all the way...
Cheaper route (no FTDI module needed) for dual channels.
Includes the LNB PSU (current limited with warning so the tiny inductors don't get popped).
Post by g0mjw » Sun Apr 06, 2025 10:22 am
The difference picotuner can't handle the very high symbol rates used by satellite TV. Nor can the minitiouner but it can handle higher rates than the picotuner. Both are adequate for DATV though, at least for all sensible transmissions. If your friend wants to receive satellite TV, they should buy a satellite TV receiver. That's not what the minitiouner or picotuner are for.
Basil
Post by Basil » Sun Apr 06, 2025 1:36 pm
Thanks Gareth and Mike. He just wants it for receiving QO100. So what's the symbol rate limitation of the PicoTuner then please?
Best regards,
g4eml
Post by g4eml » Sun Apr 06, 2025 3:12 pm
It has never been fully tested but 2 Msps is probably getting close to the limit for the USB firmware. I think the Ethernet firmware can do higher.
Basil
Post by Basil » Sun Apr 06, 2025 6:53 pm
Thank you Colin, I'll pass that on, appreciated.
Best regards,
Pa3fbx
Post by Pa3fbx » Tue Apr 08, 2025 11:01 am
The main reason why some prefer minitiouner V2 over Pico tuner is the use of the " good old" minitiouner software witch is for obvious reasons not compatible with Pico tuner.
Especially Terrestial contacts more easy (better signal feedback display) with minitiouner software.
For QO100 i would advise allways Pico tuner.
Benno, PA3FBX
Basil
Post by Basil » Tue Apr 08, 2025 1:52 pm
Ahh, right, thanks for added information Benno.
Best regards,
