GB3JT Site
Locator: JO00HV
Repeater is Work in Progress. Operational TX 24/7 Omni Slot.
TX Output Digital 1318 MHz DVB-S 4 Msymbols 1/2 FEC
RX Input Analogue 1249 MHz Analogue
RX Input Digital 1249 MHz DVB-S 4 Msymbols Auto FEC
RX Input Digital 437 MHz DVB-S 2 Msymbols Auto FEC (WIP)
Talkback: GB3HE or Echolink 71066
Website: http://www.rilges.org.uk
Stream: http://www.batc.tv/streams/gb3jt
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Wed Dec 04, 2024 7:11 pm
G8PUO wrote:
Wed Dec 04, 2024 6:32 pm
On the hardware side, obviously subject to keeping 23cm TX, hopefully, will be interested to hear some thoughts on the ideal setup.
Currently we have a hardware encoder/driver (cannot remember the make), going into a couple of drivers and PA.
The question is, rather than use the old DVB-S 4 Msymbols 1/2 FEC - maybe the repeater should have a facelift and use the Portsdown Repeater and Pi. My concern is Pi reliability, as the site is not readily accessible. The current repeater hardware was on 24/7 for a few years and never had an issue.
Thoughts on the subject, preferred settings etc. would be appreciated. TX Pics attached just for interest.
PS. ignore the screwdriver - this is a feature :)
I personally think it looks well constructed as it is ……having problems tonight with my minitouner and portsdown recognising each other …hasn’t been used recently so probably me
Steve G4HTZ
PORTSDOWN and a RYDE …
G3GJA
Re: GB3JT Site
Post by G3GJA » Wed Dec 04, 2024 8:25 pm
Hi Steve
The numbers on the end are wrong; the format is 2 letters, 2numbers, 2 letters, 2 numbers & 2 letters. For example GB3EY is located at IO93RS37ME
Don't know if you use it, but kyfry.com/grid is good.
Clive
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Wed Dec 04, 2024 8:42 pm
Hi Steve
Clive
Hi Clive
Can’t seem to get link you suggested to work ….sorry for some reason I confused myself …again …on the qra finder I use it’s
JO02GB52OB
Which is ashen close in ashen CO108JN
Steve G4HTZ
G3GJA
Re: GB3JT Site
Post by G3GJA » Wed Dec 04, 2024 9:24 pm
Hi Steve
Typo! Should be k7fry.com/grid
Clive
Re: GB3JT Site
Post by g8gtz » Thu Dec 05, 2024 2:09 pm
That's an SR systems system which runs DVB-S and MPEG-2.
To be honest you really need to replace it with a DVB-S2, H264 unit running ideally 1Ms but if it means getting on air quickly then reducing the SR to 2Ms will gain you 3dB.
See CQ-TV266 page 9 on why we suggest 1Ms.
Current thinking on repeater architecture is to run Ryde receivers outputting HDMI into the BATC HDMI controller in to a Chinese Link Pi Enc V2 encoder driving a Pluto - all of which can be paid for by a BATC bursary.
https://www.amazon.co.uk/Smartfly-info- ... B08TC7V3T6 - this encoder will do both the stream generation to drive the Pluto and a streaming channel.
https://wiki.batc.org.uk/Repeater_Controller
Looking forward to getting the NoV application.
G8PUO
Re: GB3JT Site
Post by G8PUO » Thu Dec 05, 2024 2:40 pm
Many thanks all for your comments and Noel for support. Application has been submitted.
In the interim, will look at, discuss, the BATC Repeater Controller route - thanks.
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Fri Dec 06, 2024 7:07 am
GB3JT NOV issued …apparently
I just noticed on the RSGB ETCC repeater web site that apparently the NOV for GB3JT has been issued ……I am sure it’s an error ??
Link for your information
https://ukrepeater.net/my_repeater.php?id=6232
Steve G4HTZ
G8PUO
Re: GB3JT Site
Post by G8PUO » Fri Dec 06, 2024 7:22 am
Wow, not even had time to sleep..
G4HTZ
Re: GB3JT Site
Post by G4HTZ » Fri Dec 06, 2024 7:36 am
Sure it must be an error …as there seems to be 2 applications
https://ukrepeater.net/vetting.html?filter8=TV
If not ….best you get up Detling Hill this morning 😀
Steve G4HTZ
G8YTZ
Re: GB3JT Site
Post by G8YTZ » Sun Dec 08, 2024 10:36 am
Great to see the new repeater planned for Maidstone (Detling Hill) Let me know if you need any help. Hopefully I might be able to receive it at my dad's house in Lenham, though I suspect Petts Wood will be shadowed by Wrotham. How about a 70cm or 2m input?
Hopefully I'll be on the BATC net on Tuesday.
Return to “GB3JT”
