146/147MHz NoV extension
G4ZCN
Re: 146/147MHz NoV extension
Post by G4ZCN » Sun Nov 10, 2024 8:32 am
Terry,
many thanks for the NoV update.
Barry
G4ZCN
E: b.grylls@ntlworld.com
g4nmd
Post by g4nmd » Sat Nov 01, 2025 8:55 am
A real beginer to ATV and so I have attempted to get an NoV but RSGB say they have not been authorised to issue or renew for 146/147. My assumption is that it May be possble to use the all mode section of 2m at the lower half of the band for TV BUT I want to be responsible about this so looking for advice.
Graham G4NMD
Graham Smith
G4NMD
N4GJS
Post by radiogareth » Sat Nov 01, 2025 9:49 am
A similar situation arose last year when the NOV was slow to become available for renewal/application. Some of us tried 66kS using DATV Easy and Picotuner (FFMPEG decoder) with success. Centred around 144.650MHz, it used just 100kHz of BW for great pictures and sound. You can also try H266 with DATVEasy for even better quality.
Find a local station and give it a go :-)
Post by g0mjw » Sat Nov 01, 2025 9:57 am
...and you can also use 1kW of RF power with no antenna restrictions in that part of the band. I suspect one we try that the NoV process might speed up a bit.
