November 2nd/3rd Activity Weekend
Re: November 2nd/3rd Activity Weekend
Post by M0DTS » Sat Nov 02, 2024 8:15 pm
My 2m Rx is setup for 146.5 and rolls off by 145.8.. a bit of work to use lower re-tune etc which i don't have time to do this evening, close in signals block my Rx on the /P site hence the narrow filter.
May re-schedule and do Sunday evening /p and go for 70/23cm instead if there's some tropo...
I'll post later tomorrow if so.
Post by radiogareth » Sun Nov 03, 2024 8:44 am
Thinking about reducing BW....I remembered that the latest two versions of DATVEasy offered H266 encoding (currently using V2.17). When it was first released I'm sure I tried this across the shack, with RX being done with Opentuner and choosing the FFMPEG decoding. I remember being amazed at the picture quality.
Currently sending 66ks at 12fps, audio at 8kbs which comes up with a target bitrate of 81kb/s. Very narrow as expected and the spectrum looks OK on my R&S.
Opentuner has also locked to the signal and despite the low data rate, I can see the second hand on my OBS testcard clock.
A way forward????
Post by g0mjw » Sun Nov 03, 2024 4:46 pm
Not managed to work Martin before
Screenshot 2024-11-03 163738.png (1.57 MiB) Viewed 7444 times
Took a while, but it worked!
G4FKK
Post by G4FKK » Sun Nov 03, 2024 5:29 pm
2m success with G4XAT and G0MJW today! Using 66kS, 1/2 FEC, H266. This is the all-mode section of 2m (as the 146 MHz NOV has expired.
G4XAT 2m 20241103.png[/attachment ][attachment=1]G0MJW 2m 20241103.png
First time getting pictures to/from Mike terrestrially :D
G4XAT 2m 20241103.png (1.45 MiB) Viewed 7436 times
G0MJW 2m 20241103.png (2 MiB) Viewed 7436 times
Post by g0mjw » Sun Nov 03, 2024 6:10 pm
And Rob 307km
Screenshot 2024-11-03 181015.png (504.63 KiB) Viewed 7432 times
8PSK even
Screenshot 2024-11-03 181629.png (528.95 KiB) Viewed 7432 times
Good images.
Screenshot 2024-11-03 181910.png (525.96 KiB) Viewed 7432 times
G4FKK
Post by G4FKK » Sun Nov 03, 2024 6:20 pm
And M0DTS/P for the first time ever. Still 66kS on 2m...
M0DTS_P 2m 20241103.png (1.15 MiB) Viewed 7431 times
Post by radiogareth » Mon Nov 04, 2024 7:30 am
Think we can count that as a success :-) Two images here, one H265 and one H266. The quality of H266 is really remarkable especially for moving video and 66ks :-)
Time to commission the MRF300 amps for 2m.....
G4HTZ
Post by G4HTZ » Mon Nov 04, 2024 7:41 am
Good to see some terrestrial activity
Wonder what antennas , power etc everyone was using .
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
Post by g0mjw » Mon Nov 04, 2024 8:18 am
On 4m, I was using about 5W into a 5 element yagi. I think the others were similar.
On 2m, I was using 10W into a 17 element tonna. The interesting thing is, in that part of the band, we are allowed up to 1kW and any antenna, vs the 146 MHz 50W EIRP limit. That opens up the possibility of much longer distance contacts, as stations could easily be 20 dB stronger. (Easy being a relative term of course)
G4HTZ
Post by G4HTZ » Mon Nov 04, 2024 9:39 am
Hi mike
Good results ….i think there was a bit of a lift on the weekend …but still good going with fairly low power .
Will dig out my portsdown and see what I can see …got 9 ele yagi here with mast head LNA ….can always hear the beacons in Brittany , Cornwall …when it’s on ..Northern Ireland …so reasonable take off from here
Steve G4HTZ
Steve G3GHZ
5665 ATV FM
