portsdown 4
joefran7300
Re: portsdown 4
Post by joefran7300 » Mon Jun 24, 2024 6:21 am
Hello
I build the portsdown 4 and i like to connect (I am using the GPIO board also) the PE4302 variable attenuator, can any one tell me the connections please..
73's Joe 9H1GT
Re: portsdown 4
Post by radiogareth » Mon Jun 24, 2024 8:33 am
joefran7300
Re: portsdown 4
Post by joefran7300 » Mon Jun 24, 2024 8:50 am
Many thanks for the link..i will try to connected and tested..
73's Joe 9H1GT
g6hfs
Re: portsdown 4
Post by g6hfs » Mon Jun 24, 2024 10:55 am
These are good and work well.
https://www.ebay.co.uk/itm/256509851311 ... R4T3iJ6JZA
joefran7300
Re: portsdown 4
Post by joefran7300 » Wed Jun 26, 2024 6:22 am
Hi Brian
Many thanks for the link and information..i will buy one off them..
Just like to ask one more question i build the portsdown with the Pluto and tested on my spectrum analyzer on 2.4Ghz and i can see the output of the pluto but when i put the modulation on carrier i do not any out put. May be i am doing something wrong as i am mew to the portsdown and i need to learn more on it..
73's
Joe 9H1GT
Re: portsdown 4
Post by radiogareth » Wed Jun 26, 2024 7:11 am
Joe, Have you got the correct firmware in the PD4? https://wiki.batc.org.uk/Portsdown_4_Pluto tells you what's needed, it can be checked from the PD4 menu system.
joefran7300
Re: portsdown 4
Post by joefran7300 » Wed Jun 26, 2024 7:54 am
I have to see and check as i am new to the portsdown..
many thanks
Joe
joefran7300
Re: portsdown 4
Post by joefran7300 » Wed Jun 26, 2024 7:57 am
DATV i have output but on carrier no..
joefran7300
Re: portsdown 4
Post by joefran7300 » Wed Jun 26, 2024 8:20 am
I think i found the reason why no carrier out put as it needs modulation to transmit as i found it on the PD4 from the BATC information on the PD4.
joefran7300
Re Ryde receiver
Post by joefran7300 » Tue Jul 23, 2024 9:59 am
Hello
I am building the Ryde receiver and i have a problem how to connect the GPIO board to the Raspberry PI 4 as i can not understand the pins written
on the circuit diagram of the Ryde and the pins on the PI 4.
can any one give me some information please..
many thanks
Joe 9H1GT
