PicoTuner project is released
Re: PicoTuner project is released
Post by G4EWJ » Mon Apr 29, 2024 4:57 pm
Also note:
"This board keeps the same layout as Raspberry Pi Pico, however in order to expose the 4 extra GPIOs, we sacrificed four of the GND pins (that are exposed in the original design). This allows the addition of four missing GPIO: GPIO23, GPIO24, GPIO25, GPIO29 on four of the eight GND pads."
So those 4 pins could possibly be grounded in a PicoTuner, if all the standard Pico ground pins are actually grounded. This would not be good if they are used as outputs. E.g. GPIO25 is the Pico onboard LED.
Post by g0mjw » Mon Apr 29, 2024 5:29 pm
They are grounded in the Picotuner. You could just not fit the pins I suppose but by doing that they have broken compatibility. Best stick to the recommended parts.
Mike.
