Mitsubishi Power Amplifier modules
g4saq
Post by g4saq » Fri Apr 12, 2024 4:20 pm
Heads up that the 23cms module (18Watt) has been discontinued. Enigma have just got the last few in stock but the price is now over £100. Nick at Enigma advised me that he thinks other modules in the series will be discontinued soon (and several Mitsubishi power transistors).
73, Russ.
g6hfs
Re: Mitsubishi Power Amplifier modules
Post by g6hfs » Mon Apr 15, 2024 4:22 pm
Will have to keep this version then 🙂
Pa3fbx
Post by Pa3fbx » Mon Apr 15, 2024 5:47 pm
I have some bad results with this module anyway.
I have 2 ra18H1213G in use witch are similar price range but much higher Gain and better linearity
I get easy 15 watt datv out of them.
With only 200mw in on 15Volt.
Benno
g6hfs
Post by g6hfs » Mon Apr 15, 2024 7:58 pm
My original gives 18w
G3GJA
Post by G3GJA » Mon Apr 15, 2024 8:54 pm
But how far down from the peak are the shoulders?
The bipolar M57762 and the MOSFET RA18H1213G perform well in DATV service provided you keep the power output to 5W and 6W RMS respectively. Meters like the CN-801 read about 13% high on a DATV signal.
The gain of the bipolar is about 13dB and the MOSFET version is around 23dB.
Clive G3GJA
g4saq
Post by g4saq » Tue Apr 16, 2024 1:55 pm
It was remiss of me not to have given the module number to avoid confusion. I was referring to the RA18H1213G (https://enigma-shop.com/products/mitsub ... ier-module ). I was not aware of other variants until reading the above posts.
I accept the advice that power must be kept low for linearity but this module remains the easiest way of producing useful power at 23cms. I have been unable to find any alternative solution. Ideas will be much appreciated.
73,
Russ.
Post by radiogareth » Tue Apr 16, 2024 2:07 pm
I built the G4BAO (Radcom 2009??) design but that needs a pre-driver. It did deliver 25 watts of TV though, before I TX'ed without an antenna. That let the smoke out and I have yet to fix it. Jim G7NTG did a design and PCB a while back, from memory it was even better than that. On my build list...
Don't think 'kits' as such remain available for these, but no harm in asking around I guess....
Must get on with one as I only have around 5 watts ATM.
g4saq
Post by g4saq » Wed Apr 17, 2024 2:08 pm
Hi Gareth, sorry to hear of your accident with the module. Expensive! Enigma sell a fully populated PCB to go with these modules. It's only about £8 if purchased with a module. As for a driver, the MiniCircuits PHA-102+ is a good candidate but it might need 2 of them cascaded to get the gain. Paul Wade, W1GHZ, sells some nice little PCBs to use with these MMICs.
73, Russ.
Post by radiogareth » Wed Apr 17, 2024 3:17 pm
Thanks Russ, it was actually a single device PA that I blew up, not a module. Mine is labelled with the required Pluto drive level and '5 Watts DVB' as a realistic output. Beyond that it got a bit of a mess. I'm pre-driving mine with a generic '5189' amp and it was written up in I think Winter 2021 CQTV - the "Boxer amp".
This is the amp I'm referring to https://github.com/g4bao/23cm-45W-PA
g4saq
Post by g4saq » Wed Apr 17, 2024 4:06 pm
Sorry Gareth, I clearly didn't read your message properly! Thanks for the info re the G4BAO design. The special PCB makes things tricky. I'll have to keep a look out. In the meantime, I'm building the Mitsubishi RA30H1213G amp. Benno's comments are encouraging.
73, Russ.
