PlutoPlus running modified PlutoDVB firmware
Re: PlutoPlus running modified PlutoDVB firmware
Just before leaving the shack got a bright idea...
Freqency and cpu hack was never done...
And presto...
Stable power and a working set...
Tomorrow is a test day....
Benno, PA3FBX
And presto...
Benno, PA3FBX
First test seems promising.
No need to change jumper settings inside and not yet tested the PTT out.
Found a simple bug where the power slider is not working at all..
Power is fixed in datv mode at approx -15db.
In DATV mode all the normal settings can be done, no time for all settings tested yet.
As its a Persevere copy, you need some settings when trying the several modes...
In the pass thru mode sdr console works including the power setting.
In this mode also the datv-easy is working, including the power slider.
Remember to reboot the pluto when changing from 1 mode to the other..
So all in all, besides the power slider setting in datv mode, it looks like Phill did us a great favor compiling a pluto+ instance..
But than again with the original pluto+ firmware sdr-console and datv-easy where also working and i did not needed dvb anymore..
Happy to test the firmware
- G1LPS Terry
Super great info Benno appreciated
Terry G1LPS
Terry G1LPS
Sorry for my extended absence on this, I have been busy on other projects recently and have only just picked this back up again.
I am currently building a new version based on the latest pluto source code and will post that when done.
73 Phil M0VSE
73 Phil M0VSE
- G1LPS Terry
Super Phil look forward to your next release.
The last one works flawless with Portsdown and Langstone.
Don't know if you tried but the Pluto+ with your last release and Portsdown4 on the LAN Does 4m/s nicely.
The standard Pluto cant do >2m/s.
Never tried USB as I only use LAN.
Thanks for sharing your work.
Terry G1LPS
Terry G1LPS
Things seem to have progressed so that a custom build for the Pluto+ is no longer required.
I have successfully installed the latest release of F5OEO's https://github.com/F5OEO/plutosdr-fw directly to my Pluto+ and the built-in network appears to work well. This firmware has removed the direct web interface in favour of other software control (DATV-Red seems to work well)
73 Phil M0VSE
73 Phil M0VSE
- G1LPS Terry
Interesting thanks for sharing that Phil.
Will have to give it a go are you getting gigabit on the LAN?
Your compiled version will still be the only solution for the Pluto + to run with Portsdown 4 on LAN though.
Is that correct?
Terry
Is that correct?
Terry
Hi Phill,m0vse wrote: ↑Fri Feb 09, 2024 5:23 pmThings seem to have progressed so that a custom build for the Pluto+ is no longer required.
73 Phil M0VSE
Did you play with a minitiouner connected to the Pluto+ and use it with DATV RED?
I know Evariste build longmynd into the pluto firmware and DATVred can use that to control a minitiouner witch is on the USB hub connected between a network dongle and the pluto.
I also use the pluto+ via its internal LAN connection and i wonder if i would connect the pluto to a minitiouner directly, if this than also works..
I could use a smal passive USB hub or sorting out the + and - datalines and connect it with a usb cross cable..
I still havn't tried it yet as my feeling is that lanconnetor and USB data are two different paths..
Benno
