portsdown enclosure
VK5BI
portsdown enclosure
Post by VK5BI » Sat Dec 23, 2023 3:37 am
I eventually found an ideal enclosure for my portsdown.
The enclosure holds the PI4, pluto, knucker board, minitiouner and a small audio amp.
Wayne VK5BI
F1FCO
Re: portsdown enclosure
Post by F1FCO » Wed Jan 10, 2024 5:08 pm
hello dear OM,
Do you have the references for this box?
where to buy it?
thank you for your reply
73s from F1FCO, Pierre.
VK5BI
Post by VK5BI » Wed Jan 10, 2024 10:08 pm
It is a Hammond enclosure, their p/n is 1456PK4WHBU.
In Australia they were available from both element14 and RS components, however
at that time they both had long lead times on orders for them. I purchased mine
from Digikey.
Regards
Wayne VK5BI
F1FCO
Post by F1FCO » Thu Jan 11, 2024 11:21 am
thank you Wayne,
73s from F1FCO
g1tzc
Post by g1tzc » Sun Apr 14, 2024 5:14 pm
Hi Wayne,
I am curious, can you point me in the direction of how to configure the PI4, Pluto (or Lime), knucker board, minitiouner (or Pico). I’ve seen lots of either / or but not both.
As you can tell, I am a novice to this.
Thanks,
Neil.
Post by G8GKQ » Mon Apr 15, 2024 2:03 pm
Hi Neil
You should not connect both the Knucker and MiniTiouner (or Pico Tuner) to the Portsdown at the same time. There is currently a USB conflct between the 2, so just connect the USB lead for the one that you want to use.
You can connect both simultaneously to a Ryde.
VK5BI
Post by VK5BI » Thu Apr 25, 2024 4:04 am
Hi Neil,
i built up a crude and simple 2 way usb switch. The chip and the adaptor board for it are both available from Farnell. I think my cost
was about $6 aussie for the two. It is not pretty but it works, just a toggle switch switching one pin of the chip between high and low.
The only additional part was the 78L05 regulator. A warning though the chip is only about 3mm square and has 10 pins.
Regards
Wayne
