Items for sale
Items for sale
I have the following for sale Due to ill health.
1, Portsdown4 Lime SDR Mini and Raspberry pi4,SD card, 7”Screen and Case ready to use just need 5v psu £375.Sold
2, Portsdown3 Raspbery pi3B 7” Screen SD card and case working £90 Sold
3, Bert Modderman PE1RKI Amplifier with mmic chamber complete with power module.
this is good for 1mw in 3 watt out datv. £120 Sold
4, Bert Modderman 100w 23cms SSB Amp 2 watt in 140 watt out £135 SOLD
5, Bert Modderman 2400 Mhz Amp 80 mw in 100w out never used 28 Volt (Sold)
6, 23cms G8FEK SBA 1250/1450 Pre Amp £80
7, ADALM-PLUTO boxed £100 SOLD
8, Bird 43 power meter with the following slugs 400-1000Mhz 10W 1.7-1.99Ghz 50W 100-250Mhz 5W 50-125 5W 25-1000 500W with a 50dB tap £125 SOLD
9, G7NTG power meter for 2.4Ghz never used £40 (Sold)
10, Yaesu FT-790 mk1 working but not got the portable with soft case and strap £120
The following Antennas and hard ware will be for sale soon as I get them taken down.
11, WIMO SHF 2344 23cm-Yagi 44-Element 18.1 dBd
• 44 element 23cms Yagi
• 18.1 dBd gain. 3.0m long boom.
• Multiple-optimized design according to DL6WU
• All holes of the boom drilled automatically by robot – extreme small tolerances
• N-Female connecti £120
12, 23 cm Yagi Antenna 18 Elements PA1296-18-1.5RA
£75
13, qo-100 Bullseye lnb with 5 turn helical antenna and cone £100
There is other bit when I find them.
73 Keith G0SPH
£75
73 Keith G0SPH
Re: Items for sale
Keith, I have sent you a PM....
Re: Items for sale
Hi Keith do you still have the 23cm 1mw in 3 watt out datv amplifier from Bert?
Re: Items for sale
I’m interested in 1. Port down with lime sdr mini. Have you still got it for sale.
Let me if it is. Kevin
