Had an existing hole in the front panel so used that
Share your modded Minitiouner Pics!
Re: Share your modded Minitiouner Pics!
Done a couple of Rob PE1CHYs version.
my modification of the MiniTiouner-S with 2nd USB port and 2nd LED for TS at pin 32 of the FT2232H
(thanks Benno PA3FBX for the idea)
- Front mit 2. USB und 2. LED für TS.jpg (34.42 KiB) Viewed 19930 times
- Anschluß Tuner und 2. LED für TS an Pin 32.jpg (142.81 KiB) Viewed 19930 times
- Einbau.jpg (80.38 KiB) Viewed 19930 times
- Platine Verdrahtung.jpg (59.69 KiB) Viewed 19930 times
- Platine eingebaut.jpg (92.14 KiB) Viewed 19930 times
Great job,
I just finished mine
mounted in the S...
mounted in the S...
on6py-Rudy
Here you can see the nice result of the extension of my Minitiouner-S (older version) with a second TS output. The PCB, designed by Benno PA3FBX, fits very well on the main board and can be built into the aluminum box perfectly. Do use an insulating washer between the PCB and the nut to prevent unwanted connections!
- 20230624_215441.jpg (131.83 KiB) Viewed 19785 times
- frontpaneel ON6PY.jpg (299.07 KiB) Viewed 19785 times
- 20230622_195007 klein.jpg (292.94 KiB) Viewed 19785 times
