Portsdown 4 DVB-S2 problem with Pluto (no TX)
ok2haz
Post by ok2haz » Fri Jun 09, 2023 8:07 pm
Dear OMs,
I'm having trouble using Portsdown 4 with ADALM Pluto.
If the DVB-S2 operation is set up with a Test Card or Contest Numbers source, the setup transmits OK.
But if I switch to Pi Cam, or Webcam C920 does not generate any signal:(
The configuration is as follows:
- HW ADALM Pluto Rev.C (D on the PCB)
- FW Pluto - v0.31-4-g9ceb-dirty
- Pluto - Both CPUs Enabled
- Pluto - Expanded to AD9364
- Portsdown ver. - 202304300
Please advise if anyone has encountered the same problem.
Michal OK2HAZ
g6hfs
Re: Portsdown 4 DVB-S2 problem with Pluto (no TX)
Post by g6hfs » Sat Jun 10, 2023 12:44 pm
I think your problem will be you need the white usb to 3.5mm dongle seleleted as audio mic input.
https://www.amazon.co.uk/gp/product/B08 ... UTF8&psc=1
PE1CHY
Post by PE1CHY » Sun Jun 11, 2023 8:27 am
Hi Michal,
The Portsdown should work with an "old" Logitech C920 camera. Maybe you have one of the newer types with brandname "Logi" on it instead of Logitech. These C920 have different USB VID and PId and won't work.
Easy way to find out the VID and PID is to plug in the camera on a windows computer and go to setup > device manager.
Then you select the C920 camera and look at the properties:
I have not tested with a PIcam, but the Picam may need a sound input device as Brian already wrote.
73'
Rob PE1CHY
g6hfs
Post by g6hfs » Sun Jun 11, 2023 9:54 am
I am using a Logi c920 with no problems tx works with my Pluto rev D with Portsdown 4
