error on Langstone
IU2KAC
error on Langstone
Post by IU2KAC » Mon Apr 24, 2023 7:57 am
From today the Langstone doesn't want to hear of working.
I also tried to reinstall it and update the firmware, but nothing changes.
Tried with other Pluto too!
Error message says:
<Lang_TRX_Pluto.py failed to load see/tmp/LannstoneTRX_Pluto.log>
g4eml
Re: error on Langstone
Post by g4eml » Mon Apr 24, 2023 9:00 am
What does the log file say?
Also check your sound device. If it is not working it will cause this.
IU2KAC
Post by IU2KAC » Mon Apr 24, 2023 9:16 am
where can i see the log file?
Libo IU2KAC
g4eml
Post by g4eml » Mon Apr 24, 2023 9:27 am
You need to connect to the Langstone as you did when you installed it and enter
more /tmp/LangstoneTRX_Pluto.log
Colin.
OE3GBB
Post by OE3GBB » Wed Apr 24, 2024 12:29 pm
I have the same problem here. From the log file I think it is a sound card problem. I have used two different sound devices and with Pluto and Lime so far, but no solution. Which sound card is proved to work?
73 Gerhard OE3GBB
Screen Shot 04-24-24 at 02.27 PM.PNG (32.9 KiB) Viewed 11682 times
Post by g0mjw » Wed Apr 24, 2024 12:34 pm
Looks like the wrong sound device being used? Are you using the specified dongle? See the Wiki.
OE3GBB
Post by OE3GBB » Wed Apr 24, 2024 1:07 pm
./set_sound did it! Thanks so much. 73 Gerhard
G0ILO
Post by G0ILO » Sun Apr 28, 2024 11:31 am
Hi All,
Hope you don't mind me tagging onto this thread but I have the same problem and any help would be appreciated.
I get this for the log. There's an error but I'm not sure how/if I need to deal with it.
Get this for the ./set_sound command
This is the USB audio interface I have. Looked the same in the eBay pictures but this has black instead of white 3.5mm sockets.
Cheers,
Paul G0ILO
g4eml
Post by g4eml » Sun Apr 28, 2024 9:19 pm
Paul,
Your problem is not sound card related. The one you have should work OK.
The error log indicates that the GNURadio system was not installed correctly. This is needed for Langstone to work and is normally installed automatically by the install script. However internet problems can cause installs to fail.
I would suggest re-installing Langstone.
G0ILO
Post by G0ILO » Mon Apr 29, 2024 7:03 am
Hi Colin,
Thanks for the response....I did wonder that although before posting I did try a second install and got the same result. I guess I've been unlucky twice. I'll give it another go this evening when home from work.
Cheers,
Paul.
