H266 codec
H266 codec
Is it easy to add a codec to PD4 for H266, maybe for Rx?
I see people are experimenting with this.
73 Graham
73 Graham
Re: H266 codec
We are all waiting to transmit DATV with halve the data ( or go to 4K! )
Re: H266 codec
I'm guessing it is a lot of work for a RasPi Martin?
Graham
Graham
Re: H266 codec
It's a lot of work for an Intel i9, let alone a Pi
Although decoding seems pretty unintensive, CPU wise
Best regards,
Re: H266 codec
The Portsdown will never be capable of video encoding for H266 (although it would transmit a TS from a PC doing the encoding).
As for receive, it would need the Raspberry Pi version of VLC to support H266 decoding. If someone could look at whether that is happening, then I could look at upgrading the version of VLC used in the Portsdown receiver (and possibly the Ryde).
Re: H266 codec
Is there even a main PC version of VLC that does native H266 decoding? I was under the imppression all current versions needed an add on of some sort, that in itself needed compiling. I would be very pleased to be told I am wromg though.
Best regards,
